Fresh install - cant get remote ID
ibdroid
Post by ibdroid »
When I follow the install instructions I do not get any device/remote ID from IP:8083 setup screen.
How do I get remote access ID/login?
If I go to usermanagement/firmware update I can access IP:8084 however It has errors about zboxid, prm_zbw_userid and orm:zbw_pass
See image
Usermanagement/Remote Access Management gives this error: SmartHome UI Error. Cant initialize remote access data.
I get the same result/error on jessie07-05, strech11-29 and razberry.img.zip
Also find.z-wave.com do not show local IP adress.
When I look at install progress I see this error
First install, getting Remote ID
--2018-01-26 01:26:36-- http://find.zwave.me/zbw_new_user
Resolving find.zwave.me (find.zwave.me)... 46.20.244.72
Connecting to find.zwave.me (find.zwave.me)|46.20.244.72|:80... connected.
HTTP request sent, awaiting response... 500 Internal Server Error
2018-01-26 01:26:37 ERROR 500: Internal Server Error.
Skjermbilde (9).png (72.76 KiB) Viewed 13955 times
ibdroid
Re: Fresh install - cant get remote ID
Post by ibdroid »
Seems there are others with similar problems recently.
Question then is, shoud I wait until this adress is accessible: http://find.zwave.me/zbw_new_user
and then do a re-install?
bgr
Post by bgr »
Same problem here. Contacted support the other day and they said it would be up shortly. But given that was two days ago I guess that didn't mean today or tomorrow, more like someday. Can't set up Alexa integration without a remote ID.
Anybody know how this server is involved in the Alexa process? Is it a proxy between Alexa and the Razberry? If it is, I'm concerned about both security and reliability based on what I've seen with Z-wave.me already. No guarantees this server will stay operational looking at the size of Zwave, but more important, I don't know if I want this server having remote capabilities to all of my z-wave devices. At least the servers appear to be in Switzerland.
Had high hopes for this solution, but between issues like this and the horrible range of the Razberry (like 3m in my house,) I may just end up buying a SmartThings hub.
teklov
Post by teklov »
I have same problem. Can´t get a remote access ID/login.
--2018-01-28 07:18:06-- http://find.zwave.me/zbw_new_user
Slår upp find.zwave.me (find.zwave.me)... 46.20.244.72
Ansluter till find.zwave.me (find.zwave.me)|46.20.244.72|:80... ansluten.
HTTP-begäran skickad, väntar på svar... 500 Internal Server Error
2018-01-28 07:18:07 FEL 500: Internal Server Error.
pwm
Post by pwm »
Server issue seems to be resolved now. Now possible to register new user.
Max Faye-Wevle
Post by Max Faye-Wevle »
Hi!
I have the same problem. Sent a email a couple days ago but the havent answer jet. Anyone have some pointer for a Rasberry/Razberry noob?
It would be appreciated.
