UZB Firmware update issue
Stephane
Post by Stephane »
I did a firmware update with Z-Way on Windows 10 / expert mode on my UZB USB stick, from 5.02 to 5.06 (version proposed by the program), after the update, the UZB is no more recognized by Windows, unknow USB device, and didn't map anymore to a COM port.
On Linux I have this status:
[ 2.156754] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
[ 2.257641] usb 1-1.4: device descriptor read/64, error -32
[ 2.476807] usb 1-1.4: device descriptor read/64, error -32
[ 2.696751] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[ 2.796786] usb 1-1.4: device descriptor read/64, error -32
[ 3.016786] usb 1-1.4: device descriptor read/64, error -32
[ 3.236812] usb 1-1.4: new full-speed USB device number 6 using dwc_otg
[ 3.426295] usbcore: registered new interface driver brcmfmac
[ 3.676768] usb 1-1.4: device not accepting address 6, error -32
[ 3.777163] usb 1-1.4: new full-speed USB device number 7 using dwc_otg
[ 4.216720] usb 1-1.4: device not accepting address 7, error -32
[ 4.216815] usb 1-1-port4: unable to enumerate USB device
Anyway to recover it ?
Re: UZB Firmware update issue
Looks dead. Have you unplugged during upgrade?
Or may be bad contact in USB?
Stephane
Post by Stephane »
Not an UBS bad contact unfortunatly. I didn't remove it during the flash, the message was saying that evering finished fine, but…
Is it any technical tools or way to reflash it with a working firmware ?
Have you upgraded bootloader first ? It had to be first in the list. For so old dongle this is mandatory. All prior to 5.05 have to get bootloader upgraded first
