20:58 | "Cannot create vDev based on: 4-0-113: TypeError: Cannot read property 'forEach' of null"
20:58 | "Cannot create vDev based on: 4-0-113: TypeError: Cannot read property 'forEach' of null"Messages from log:
[2018-07-04 20:58:52.920] [I] [core] Notification: error (core): Cannot create vDev based on: 4-0-113: TypeError: Cannot read property 'forEach' of null
[2018-07-04 20:58:52.924] [I] [core] TypeError: Cannot read property 'forEach' of null
at maskArrayToTypes (automation/modules/ZWave/index.js:5405:21)
at automation/modules/ZWave/index.js:5420:83
at Array.forEach (native)
at ZWave.parseAddCommandClass (automation/modules/ZWave/index.js:5393:25)
at ZDataHolder.<anonymous> (automation/modules/ZWave/index.js:5634:12)
[2018-07-04 20:58:53.075] [I] [core] Notification: error (core): Cannot create vDev based on: 4-0-113: TypeError: Cannot read property 'forEach' of null
[2018-07-04 20:58:53.077] [I] [core] TypeError: Cannot read property 'forEach' of null
[2018-07-04 20:58:53.079] [I] [core] Notification: error (core): Cannot create vDev based on: 4-0-113: TypeError: Cannot read property 'forEach' of null
[2018-07-04 20:58:53.081] [I] [core] TypeError: Cannot read property 'forEach' of null
[2018-07-04 20:58:53.083] [I] [core] Notification: error (core): Cannot create vDev based on: 4-0-113: TypeError: Cannot read property 'forEach' of null
[2018-07-04 20:58:53.085] [I] [core] TypeError: Cannot read property 'forEach' of null
[2018-07-04 20:58:53.093] [I] [core] Notification: device-info (device-OnOff): {"dev":"ON-WZ Fenster Auf-Zu","l":"off","location":4}
[2018-07-04 20:58:53.300] [I] [core] Notification: error (core): Cannot create vDev based on: 4-0-113: TypeError: Cannot read property 'forEach' of null
[2018-07-04 20:58:53.301] [I] [core] TypeError: Cannot read property 'forEach' of null
[2018-07-04 20:58:54.281] [I] [core] Notification: error (core): Cannot create vDev based on: 4-0-113: TypeError: Cannot read property 'forEach' of null
... and so on ...Excerpt from my telegram log:
0E0D0C0B0445011C012000FA31270000007105000000FF06170000F0
0E0D0C0B: Home ID
04: Source 04=ON-WZ Sen(B)
4501: Frame Control
4=0100
0: routed=no
1: ACK required=yes
0: low power=no
0: speed modified=no
5: Frame Type=?NDef
0: Beam Control (Battery support option)=no beam
1: Sequence No=1
1C: Total Length in Bytes=28
01: Destination 01=Z-Way
2000FA31270000007105000000FF06170000: Param(s)
F0: Checksum
[2018-07-04 20:58:52.068] #1 FT5 04=ON-WZ Sen(B) >> 01=Z-Way - 0x2000FA31270000007105000000FF06170000
Complete used route = 04=ON-WZ Sen(B) -> 01=Z-Way
0E0D0C0B0445011C012000FA22082600007105000000FF06170000EA
0E0D0C0B: Home ID
4501: Frame Control
4=0100
0: routed=no
1: ACK required=yes
0: low power=no
5: Frame Type=?NDef
1: Sequence No=1
2000FA22082600007105000000FF06170000: Param(s)
EA: Checksum
[2018-07-04 20:58:53.977] #1 FT5 04=ON-WZ Sen(B) >> 01=Z-Way - 0x2000FA22082600007105000000FF06170000
0E0D0C0B0445011C012000FA22272200007105000000FF06170000C1
0E0D0C0B: Home ID
4501: Frame Control
4=0100
0: routed=no
1: ACK required=yes
0: low power=no
5: Frame Type=?NDef
1: Sequence No=1
2000FA22272200007105000000FF06170000: Param(s)
C1: Checksum
[2018-07-04 20:58:53.051] #1 FT5 04=ON-WZ Sen(B) >> 01=Z-Way - 0x2000FA22272200007105000000FF06170000
0E0D0C0B01050119042207FA22272200000401222722000039
0E0D0C0B: Home ID
01: Source 01=Z-Way
0501: Frame Control
0=0000
0: routed=no
0: ACK required=no
0: low power=no
5: Frame Type=?NDef
1: Sequence No=1
19: Total Length in Bytes=25
04: Destination 04=ON-WZ Sen(B)
2207FA222722000004012227220000: Param(s)
39: Checksum
[2018-07-04 20:58:53.232] #1 FT5 01=Z-Way >> 04=ON-WZ Sen(B) - 0x2207FA222722000004012227220000
Complete used route = 01=Z-Way -> 04=ON-WZ Sen(B)
0E0D0C0B0105011904220700312722000004012227220000D0
0E0D0C0B: Home ID
01: Source 01=Z-Way
0501: Frame Control
0=0000
0: routed=no
0: ACK required=no
0: low power=no
5: Frame Type=?NDef
1: Sequence No=1
220700312722000004012227220000: Param(s)
D0: Checksum
[2018-07-04 20:58:53.035] #1 FT5 01=Z-Way >> 04=ON-WZ Sen(B) - 0x220700312722000004012227220000
0E0D0C0B0445011C012000FA22271900007105000000FF06170000FA
0E0D0C0B: Home ID
4501: Frame Control
4=0100
0: routed=no
1: ACK required=yes
0: low power=no
5: Frame Type=?NDef
1: Sequence No=1
2000FA22271900007105000000FF06170000: Param(s)
FA: Checksum
[2018-07-04 20:58:53.941] #1 FT5 04=ON-WZ Sen(B) >> 01=Z-Way - 0x2000FA22271900007105000000FF06170000
0E0D0C0B0105011904220700312719000004012227190000D0
0E0D0C0B: Home ID
01: Source 01=Z-Way
0501: Frame Control
0=0000
0: routed=no
0: ACK required=no
0: low power=no
5: Frame Type=?NDef
1: Sequence No=1
220700312719000004012227190000: Param(s)
D0: Checksum
[2018-07-04 20:58:53.520] #1 FT5 01=Z-Way >> 04=ON-WZ Sen(B) - 0x220700312719000004012227190000
0E0D0C0B0445011C012000FA13270223007105000000FF06170000F3
0E0D0C0B: Home ID
4501: Frame Control
4=0100
0: routed=no
1: ACK required=yes
0: low power=no
5: Frame Type=?NDef
1: Sequence No=1
2000FA13270223007105000000FF06170000: Param(s)
F3: Checksum
[2018-07-04 20:58:53.427] #1 FT5 04=ON-WZ Sen(B) >> 01=Z-Way - 0x2000FA13270223007105000000FF06170000
0E0D0C0B0105011904220700222702230004011327022300F2
0E0D0C0B: Home ID
01: Source 01=Z-Way
0501: Frame Control
0=0000
0: routed=no
0: ACK required=no
0: low power=no
5: Frame Type=?NDef
1: Sequence No=1
220700222702230004011327022300: Param(s)
F2: Checksum
[2018-07-04 20:58:53.209] #1 FT5 01=Z-Way >> 04=ON-WZ Sen(B) - 0x220700222702230004011327022300
0E0D0C0B010501190422070040270223000401132702230090
0E0D0C0B: Home ID
01: Source 01=Z-Way
0501: Frame Control
0=0000
0: routed=no
0: ACK required=no
0: low power=no
5: Frame Type=?NDef
1: Sequence No=1
220700402702230004011327022300: Param(s)
90: Checksum
[2018-07-04 20:58:53.031] #1 FT5 01=Z-Way >> 04=ON-WZ Sen(B) - 0x220700402702230004011327022300
0E0D0C0B0445011C012000FA13270224007105000000FF06170000F4
0E0D0C0B: Home ID
4501: Frame Control
4=0100
0: routed=no
1: ACK required=yes
0: low power=no
5: Frame Type=?NDef
1: Sequence No=1
2000FA13270224007105000000FF06170000: Param(s)
F4: Checksum
[2018-07-04 20:58:53.938] #1 FT5 04=ON-WZ Sen(B) >> 01=Z-Way - 0x2000FA13270224007105000000FF06170000
- How do I get rid of that messages?
