RaZberry Frequencies issues
Pusky
Post by Pusky »
My Razberry showed US & IL under http://192.168.1.25:8083/expert/#/network/control..
upgraded firmware to 5.23 and now it shows EU RU IN CN, why is this??
was having issues including RaZberry as a secondary z-wave controller, read on the internet to upgrade firmware, so I went to http://192.168.1.25:8083/expert/#/uzb and it showed upgrade from 5.04 to 5.22, once I did it showed JP TW KR, when I rebooted it showed upgrade to 5.22 EU US ...., so I picked that and it would not show US, went to the firmware again and it showed a 5.23 only so I upgraded it hopping it would fix the new issue. but it did not..
the link https://z-wave.me/support/uzbrazberry-firmwares/ shows version 5.32 but my page " Your stick uses the latest firmware" but I do not have a stick, it is a raZberry??
Please Help,
Pasquale
Re: RaZberry Frequencies issues
5.32 is currently hidden from public
The problem happens on upgrade from old firmwares - frequency resets to EU. To fix it please enter IP:8083/JS/Run/zway.ZMEFreqChange(3) to switch to US.
Pusky
Post by Pusky »
Great thank you, It worked like a charm.
Quick other question if you do not mind. This all started so that I could connect the RaZberry to my existing Z-wave home automation network. as a secondary controller.
I go to the http://192.168.1.25:8083/expert/#/network/control and go to the "Enter / Leave different Networks" and I then click on the "Include into Network" but it never connects. is this normal, or possibly a security control?
I want to use the RaZberry as a bridge between Z-Wave and MQTT.
I can also start a new forum thread if needed...
Cheers, and thank you for the Help..
Pasquale
Better to make new threads for that.
Should work like you mentioned.
Make sure frequencies are same, make sure the other controller is in Add mode. Use Enter/Leave network on RaZberry.
