UZB Firmware Update from 5.07 to 5.27 fails
schreibubi
Re: UZB Firmware Update from 5.07 to 5.27 fails
Post by schreibubi »
I just tried upgrading again using 3.0.0-rc15, but I'm still stuck at 5.07. I've attached the log-file, but can't see anything which sticks out.
Hope we can get this fixed!
Joerg
z-way-server.txt.gz
Upgrade log
(325.61 KiB) Downloaded 1225 times
Please try with v2.3.8-rc5. It will work. On v3.0.0-rc15 another branch is used and the required patch is not yet merged.
Make sure to upgrade bootloader first.
stefxx
Post by stefxx »
I just tried with 2.3.8rc5. Unfortunately the process doesn't even start now, but errors with this message:
Z-Wave Expert UI - ERROR
Unable to update data. /ZWave.zway/ZMEFirmwareUpgrade
Apart from upgrading to 2.3.8rc5 I don't recall making any other changes...
Can you send in PM remote access credentials or provide logs? This looks strange
stefxx
Post by stefxx »
With the help of PoltoS, I was finally able to upgrade to 5.27! According to PoltoS: "there is some dependencies problem in Jessie with conflicting libraries and currently http requests are not supported."
Upgrading to Stretch resolved this issue. Thanks!
steinis
Post by steinis »
stefxx wrote:
12 Aug 2018 11:01
Did you find a solution? I have the same error as you after upgrading.
Also after upgrading to v2.3.8-rc5 my MQTT plugin stop sending out message(responding to received message is stil working)
stefxx
Post by stefxx »
See the post above yours. Upgrade to Stretch is the solution.
steinis
Post by steinis »
OK thanks. How do I do this I have only downloaded the image from z-way and installed it on a rpi.
steinis
Post by steinis »
ahh that completely crashed my system, did you update to Stretch after upgrading to V2.3.8-rc5?
Under the installation of Stretch you have to answer some question to replace or keep some config files. What did you pick?
