My Sensitive strip door sensor is not changed in the z-way UI, but I can se its working from the expert menu(SensorBinary is switching true/false).
I have tried to exclude and include it a number of times.
Sensative Door sensor not reporting in UI
Re: Sensative Door sensor not reporting in UI
This is not showing in the UI for me neither (3.0.0rc15)
Expert UI interview status (100%):
Device Name
Sensative Strip
Device Id
29
Brand
Sensative AB
Device Type
Notification Sensor
Wireless Activity
deep sleep
Application version
0.4
SDK version
6.51.06
Command Class
Basic • SensorBinary • AssociationGroupInformation • DeviceResetLocally • ZWavePlusInfo • Configuration • Alarm • ManufacturerSpecific • PowerLevel • Battery • Wakeup • Association • Version •
[code]
I can confirm it reporting by log:
[code]
[2018-09-20 13:43:38.639] [D] [zway] SETDATA devices.29.data.lastReceived = 0 (0x00000000)
[2018-09-20 13:43:38.640] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.eventParameters = byte[0]
[2018-09-20 13:43:38.640] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.event = 22 (0x00000016)
[2018-09-20 13:43:38.643] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.eventString = "Window/door is open"
[2018-09-20 13:43:38.643] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.status = 255 (0x000000ff)
[2018-09-20 13:43:38.644] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6 = Empty
[2018-09-20 13:43:42.146] [D] [zway] SETDATA devices.29.data.lastReceived = 0 (0x00000000)
[2018-09-20 13:43:42.147] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.eventParameters = byte[0]
[2018-09-20 13:43:42.147] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.event = 22 (0x00000016)
[2018-09-20 13:43:42.149] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.eventString = "Window/door is open"
[2018-09-20 13:43:42.150] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.status = 255 (0x000000ff)
[2018-09-20 13:43:42.150] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6 = Empty
[2018-09-20 13:43:46.041] [D] [zway] SETDATA devices.29.data.lastReceived = 0 (0x00000000)
[2018-09-20 13:43:46.042] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.eventParameters = byte[0]
[2018-09-20 13:43:46.042] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.event = 23 (0x00000017)
[2018-09-20 13:43:46.045] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.eventString = "Window/door is closed"
[2018-09-20 13:43:46.045] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.status = 255 (0x000000ff)
[2018-09-20 13:43:46.046] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6 = Empty
[2018-09-20 13:43:46.103] [D] [zway] SETDATA devices.29.data.lastReceived = 0 (0x00000000)
[2018-09-20 13:43:46.103] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.eventParameters = byte[0]
[2018-09-20 13:43:46.104] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.event = 23 (0x00000017)
[2018-09-20 13:43:46.107] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.eventString = "Window/door is closed"
[2018-09-20 13:43:46.107] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.status = 255 (0x000000ff)
[2018-09-20 13:43:46.107] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6 = Empty
[2018-09-20 13:43:46.768] [D] [zway] SETDATA devices.29.data.lastReceived = 0 (0x00000000)
[2018-09-20 13:43:46.768] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.eventParameters = byte[0]
[2018-09-20 13:43:46.768] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.event = 23 (0x00000017)
[2018-09-20 13:43:46.771] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.eventString = "Window/door is closed"
[2018-09-20 13:43:46.771] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6.status = 255 (0x000000ff)
[2018-09-20 13:43:46.771] [D] [zway] SETDATA devices.29.instances.0.commandClasses.113.data.6 = Empty
[code]Re: Sensative Door sensor not reporting in UI
Ahh crap. So basically this unit is useless with z-way?
Which zway version are you on?
Running firmware v2.3.8-rc6 with UI version 1.9.0
Is there a way to map the signal from expert UI and make a dummmy device so I can use it in my logic?
And news here? Will there be a fix for this component soon?
