Z-Uno core version and device version mismatch
sil
Post by sil »
I got this error:
Tried to <tools> <burn bootloader>
and got this error
Arduino : 1.8.7 (Mac OS X), TD: 1.44, Carte : "Z-Wave>ME Z-Uno, Europe, Disabled, Disabled, Disabled, Disabled"
java.lang.NullPointerException
at cc.arduino.packages.uploaders.SerialUploader.burnBootloader(SerialUploader.java:362)
at processing.app.Editor.lambda$handleBurnBootloader$61(Editor.java:2435)
at java.lang.Thread.run(Thread.java:748)
Erreur lors de la gravure de la séquence d'initialisation.
What do I wrong ?
Re: Z-Uno core version and device version mismatch
Sure you have selected the port first?
sil
Post by sil »
yes ,of course !
If I download an example:
RadioBlink.ino
--- USING a list of libraries from:
/Users/sw/Library/Arduino15/packages/Z-Uno/hardware/zw8051/2.1.4/libraries
/Users/sw/Documents/Arduino/libraries
*** Collecting prototypes...
Preprocessing file: Custom.c with SDCPP...
Preprocessing file: RadioBlink.cpp with SDCPP...
Compiling RadioBlink_sdcpp_.cpp ...
Compiling RadioBlink_sdcpp_.cpp ...Compiling file "LLCore_arduino.c" by means of SDCC...
sdcc: Calling preprocessor...
sdcc: sdcpp -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include/mcs51 -isystem /usr/local/share/sdcc/include/mcs51 -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include -isystem /usr/local/share/sdcc/include LLCore_arduino.c
sdcc: Generating code...
sdcc: Calling assembler...
sdcc: sdas8051 -plosgffw LLCore_arduino.rel LLCore_arduino.asm
Compiling file "Print_ucxx.c" by means of SDCC...
sdcc: sdcpp -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include/mcs51 -isystem /usr/local/share/sdcc/include/mcs51 -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include -isystem /usr/local/share/sdcc/include Print_ucxx.c
sdcc: sdas8051 -plosgffw Print_ucxx.rel Print_ucxx.asm
Compiling file "Stream_ucxx.c" by means of SDCC...
sdcc: sdcpp -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include/mcs51 -isystem /usr/local/share/sdcc/include/mcs51 -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include -isystem /usr/local/share/sdcc/include Stream_ucxx.c
sdcc: sdas8051 -plosgffw Stream_ucxx.rel Stream_ucxx.asm
Compiling file "HardwareSerial_ucxx.c" by means of SDCC...
sdcc: sdcpp -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include/mcs51 -isystem /usr/local/share/sdcc/include/mcs51 -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include -isystem /usr/local/share/sdcc/include HardwareSerial_ucxx.c
sdcc: sdas8051 -plosgffw HardwareSerial_ucxx.rel HardwareSerial_ucxx.asm
Compiling file "HLCore_ucxx.c" by means of SDCC...
sdcc: sdcpp -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include/mcs51 -isystem /usr/local/share/sdcc/include/mcs51 -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include -isystem /usr/local/share/sdcc/include HLCore_ucxx.c
sdcc: sdas8051 -plosgffw HLCore_ucxx.rel HLCore_ucxx.asm
Compiling file "RadioBlink_ucxx.c" by means of SDCC...
sdcc: sdcpp -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include/mcs51 -isystem /usr/local/share/sdcc/include/mcs51 -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include -isystem /usr/local/share/sdcc/include RadioBlink_ucxx.c
sdcc: sdas8051 -plosgffw RadioBlink_ucxx.rel RadioBlink_ucxx.asm
sdcc: sdcpp -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include/mcs51 -isystem /usr/local/share/sdcc/include/mcs51 -isystem /Users/sw/Library/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.70/zuno_toolchain/sdcc//bin/../share/sdcc/include -isystem /usr/local/share/sdcc/include main.c
sdcc: sdas8051 -plosgffw main.rel main.asm
sdcc: Calling linker...
sdcc: sdld -nf main.lk
Making firmware file: RadioBlink.ino-0214.hex ...packihx: read 45 lines, wrote 71: OK.
Fixing ISR table in RadioBlink.ino-0214.hex ...Making binary firmware file RadioBlink.ino-0214.bin. Using in Z-Way for wireless update procedure.[Done]
Elapsed:4.69545507431 s
Le croquis utilise 936 octets (2%) de l'espace de stockage de programmes. Le maximum est de 32256 octets.
Les variables globales utilisent 156 octets de mémoire dynamique.
Openning port ..............................
Openning port .............................. OK
Stoping the user code ..............................
Stoping the user code .............................. OK
Closing port ..............................
Closing port .............................. OK
RAW Info:
AA AA BB BB 01 15 01 10
00 01 02 09 99 DA E7 15
FIRMWARE DATA
REVISION:02. 9
Z-WAVE FREQUENCY:EU
ORIGINAL FW. CRC32: 99 DA E7 15
Z-Uno core version and device version mismatch. You have 2.0.9 firmware version on the board. Core version is 2.1.4. Please upgrade the bootloader.
Une erreur est survenue lors du transfert du croquis
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
You need to do Burn bootloader first to upgrade your bootloader to match the latest source code you use.
sil
Post by sil »
Yes I understood; I tried as my first post:
and got this error
What do I wrong ????
sil
Post by sil »
What should I do ?
sil
Post by sil »
Installed the software on a PC same error as the MAC !
Sure the port is correct?
