Can not remove associations in Expert UI
brusan
Post by brusan »
Running v2.3.8 with UI v1.9.0 under Razberry.
I made an experimental setup with a Fibaro Dimmer 2 and a WallMote Quad to test group associations. After realizing that unless both devices involved in a group association has the same security scheme, the association will not work, I excluded the WallMote from the system in order to do a new inclusion of it, this time with security enabled. During the test, I also erroneously created several associations from the Fibaro dimmer to the WallMote, in reverse to what is correct.
Before including the WallMote, I needed to remove the associations I created during the test. It turns out that this is not doable in the expert UI. I open Device and Active associations and find the associations listed for the Fibaro device. Clicking "Change" only leads me to the Association page for the Fibaro Device and there are no associations listed there other than the Life line associations to the Z-Way.
How do I remove associations in Z-wave.me?
Including screen shots of the UI.
The attachment fibaro associations.PNG is no longer available
fibaro associations.PNG (14.56 KiB) Viewed 15366 times
brusan
Re: Can not remove associations in Expert UI
Post by brusan »
Just to add to the above, it seems a bit strange that associations for devices that have been excluded (=removed from the controller) remains in the UI as is the case with device #31 above.
Trying once more to include the screen dump...
fibaro device.PNG (91.82 KiB) Viewed 15344 times
enbemokel
Post by enbemokel »
Hi, I have an equal problem, can´t change or delete associations from my Aeotec Wall Quad:
Neue Bitmap.gif (10.2 KiB) Viewed 15340 times
enbemokel
Post by enbemokel »
If I click the button on the right side "Change" and enter the Expert Menu, there is nothing shown. Only the Z-Way lifeline....
Strange
Gonin Configuration/your device/associations
enbemokel
Post by enbemokel »
Hi Polto, did it, nothing to see or to do. I also can´t set a new association, as the device 10 isn´t shown in the menu.
Any idea?
brusan
Post by brusan »
[tag]PoltoS[/tag] "Gonin Configuration/your device/associations" does not help at all, the associations does not appear there. They are shown if I go Device/Active Associations but not via Configuration/select device/Association. Does not matter if I wake up the Wall Quad or not, nothing there.
I have also tried to restart the entire Raspberry Pi - no change for the better.
Can I remove the associations via the API like
[ip]:8083/JS/Run/zway.devices[nodeId].Association.Remove(GroupId, AssocNodeId) or if it is a multi:
[ip]:8083/JS/Run/zway.devices[nodeId].MultiChannelAssociation.Set(GroupId, AssocNodeId, AssocInstanceId)
I have temporarily "solved" the problem by deleting (exclude) the devices in question but I'm not confident there are no dangling associations lurking in the system? I think there used to be a file somewhere where all the associations was listed but I can not find it any more.
Br / Brusan
brusan
Post by brusan »
I think there is a bug in the listing of active associations. Include one example of device #44 that according to the list of active associations, have two active associations. When clicking the "Change" icon the association page for the device #44 is shown but there are no associations listed?! This seems like a bug to me.
The attachment Unit_ActiveAssociations.PNG is no longer available
brusan
Post by brusan »
Could not get image 2 to show up in the thread. Trying to put it here:
brusan
Post by brusan »
I'm still having problems with associations that point to devices that no longer exist and the fact that current associations are not listed on the Associations tab in Expert view. I really need some advice here...
