ZUNO_WUPFLAGS_INT1_KEYSCAN - No wake up at Pins 19-22?
niles23
Post by niles23 »
I don't know if I got it right, therefore the following question: I thought in KEYSCAN MODE the zuno wakes up from sleep if one of the pins(17-23) goes to low. That doesn't work at my board. The Zuno only wakes up by pin 17, 18 and 23 going low.
Ports 17-23 are INPUT_PULLUPs and I tried to connect them with the ground. Zuno wakes up at pin 17, 18 and 23. The ports 19-22 only work a short period after the wake up (1 s).
Is this normal? In the References I can't find a clear answer (for example if the zuno wakes up on every key...).
Thank you.
setup:
  pinMode(17, INPUT_PULLUP);
  pinMode(18, INPUT_PULLUP);
  pinMode(19, INPUT_PULLUP);
  pinMode(20, INPUT_PULLUP);
  pinMode(21, INPUT_PULLUP);
  pinMode(22, INPUT_PULLUP);
  pinMode(23, INPUT_PULLUP);
  zunoSetWUOptions(ZUNO_WUPFLAGS_INT1_KEYSCAN);
  zunoSetBeamCountWU(30);
 loop:
    delay(10);
    zunoSendDeviceToSleep();
Re: ZUNO_WUPFLAGS_INT1_KEYSCAN - No wake up at Pins 19-22?
We confirm the issue. Will be fixed in 2.1.5
niles23
Post by niles23 »
Thank you!
niles23
Post by niles23 »
The Bugfix is still not released? Or where can I find it?
We are working hard to release the beta. Hope next week but can't promise as there are ongoing tests right now
niles23
Post by niles23 »
thank you for the new late release (beta).
Sadly the problem still exists and therefore a keypress doesn't wake up the zuno. It only works approximately a second after going to sleep...
Thanks, we have fixed this internally. Will be part of the next beta (soon)
niles23
Post by niles23 »
Perfect, its working now. Thank you for the bugfix :-)
Regards and a sunny hello
Happy to know!
Thanks for the confirmation
