Remove Failed Node not working v3.0.0
añep
Post by añep »
I have upgraded to v3.0.0 from v2.3.8 since a month ago, and I have nodes failed and I can't remove this nodes for re-includes. Clear caches is done. I use Razberry v2.
añep
Re: Remove Failed Node not working v3.0.0
Post by añep »
From 8083/smarthome don't working remove either. The problem occurs with any device that you want to remove, in expert the buttons are always disabled and in smarthome let it do it but it does not work, the devices are deleted, but never disapear.
Are they marked as failed in the expert UI? If not, please try to ping them by sending NOP on the Devices Status page.
If yes, please provide remote access so we can check it.
añep
Post by añep »
05 Sep 2019 23:53
Yes, as seen in the first capture, nodes 6 and 8 are as failed in expert UI. What data do you need for remote access?
boxId/admin password. In PM, please
añep
Post by añep »
07 Sep 2019 01:37
Sent.
Thanks.
Please try this fix:
https://github.com/Z-Wave-Me/ExpertUI/c ... 972a7537c2
You need to find the corresponding line in build.js
añep
Post by añep »
17 Sep 2019 00:39
This has fixed it.
Thanks.
Clubber2000
Post by Clubber2000 »
I have got the same problem. I cant remove failed battery nodes like in versions before.
Could you olease explain the solution above a little more detailed. I am an absolute Linux and programming noob.
Must I replace the line 285: if (ZWaveAPIData.devices[nodeId]) {
with
if (ZWaveAPIData.devices[nodeId] && ZWaveAPIData.devices[nodeId].data.publicKey) {
in which file? build.js or control.js?
Where can I find the file on the rasberry?
Do you think there will be an update for the 3.0.0 version which will fix this problem without changing the lines?
Thanks in advance.
in build.js. Or just wait a bit - we are making a new build with this fix.
