Z-Way v3.0.0 Release
michael.seitz
Re: Z-Way v3.0.0 Release
Neither can I, but I hope PoltoS comment "We will update mobile apps vey soon for both iOS and Android" (https://forum.z-wave.me/viewtopic.php?f ... ios#p83662) means, that after the apps are updated it will work again.
Had the same problem.AlesKO wrote: ↑16 Aug 2019 12:39Looks like.
Well, there was actually problem with scenes and schedules, so I thought I am not full on 3.0.0. version. All elements in my scene were red and with error text saying that elements does not exists. And no functionality/option to repair rule. On the other hand scene works fine (even today).
And there was also text on Z-Way UI upgrade page saying my firmware version is 2.3.8. ??.
We will solve this bug later. Now I am stucked and can not acces Z-Way UI.
Yesterday I repeated procedure of installing 3.0.0.:
sudo apt-get update
sudo apt-get install dirmngr -y
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 7E148E3C
sudo bash -c 'echo "deb https://repo.z-wave.me/z-way/raspbian stretch main contrib" > /etc/apt/sources.list.d/z-wave-me.list'
sudo apt-get update
sudo apt-get install z-way-full
No difference, problem stil exists. And most things were not updated because they are 'already installed'.
Please help me I really do not know what to do.
Alex
Try running:
sudo apt-get --reinstall install -o Dpkg::Options::="--force-confmiss" -o Dpkg::Options::="--force-confold" -y z-way-server
Thanks for this post, my system is up and running again.
Nico
Nico
Thanks for the hint with browser! I tried it first with Safari and couldn't login, also had 'error_load_data' above the login window. But with Chrome it worked fine.fez wrote: ↑27 Jul 2019 11:09I have the same issue after the update:
"User not found. Please check your login or password"
None of the above measures worked.
Just for info, I am upgrading from Jessie 2.3.8:
- upgraded from Jessie to Stretch, worked fine
- upgrading to 3.0.0 as described in the other post
I also tried a fresh install, but after the restore I have the same issue.
Update:
I used Firefox for all my trials and (still) failed.
Finally I tried it in Edge and it worked fine, could log in.
... it might be browser related, so if you have the same issue, try another browser
Hello
Do someone have a fix for this:
"prm_fw_curver: Err(1.18.3): main.c: 501: The spawned process 'get_z-way_version.sh' has exited with code 1 and says:
which comes instead of showing version 3.0.0 on the firmware update page.
Running 3.0.0 on stretch from fresh..
This is a known issue. Just skip it for now, will be fixed in next versions. Does not harm anything
ok
Thanks!
there is an update 3.0.1 listed; is it safe to install? Or can it ruin my setup again...
Had 3.0.0 up and running following your howto for upgrade to stretch and upgrade from 2.3.8. Got tempted to update via firmware update page when v 3.0.0 became listed as latest available update. the update went unatended as I had to leave home for some hours. I guess i missed out some important yes /no during the process.. reboot afterwards made it look like there were no zway installed at all..
anyway 3.0.0 fresh on stretch works great now
Thanks!
Hello.
I've clicked "open updater" and I've got this for few hours so I guess that something is wrong
Just to correct and avoid confusion: there was no browser issue. My problem was at that point that I didn't clean the cookies. I had some difficulty at first, but later Poltos posted some additional tips to solve this.peshay wrote: ↑18 Sep 2019 09:43Thanks for the hint with browser! I tried it first with Safari and couldn't login, also had 'error_load_data' above the login window. But with Chrome it worked fine.fez wrote: ↑27 Jul 2019 11:09I have the same issue after the update:
Update:
If you clear the browser cache and cookies as well it should work. ... it did for me.
... the version 3.0.0 runs very well on my side since then.
It is a nice upgrade, I am very pleased with it.
Saved my Z-Way life after trying to upgrade to version 3.0.0! Thanks!chrisb wrote: ↑12 Sep 2019 01:12Had the same problem.
Try running:
-Marco-
-Marco-
