Hello, neighbours and friends...
I have been using a Raspberry pi 3 + Razberry for a while. Recently I updated to 3.0.0, and as it went wrong, I completely uninstalled it and reinstalled from scratch and everything went fine that time.
In my config a Only had a Door Sensor (Aeotec) and a fire alarm (Fibaro), and both work great (I guess Fibaro sensor works great, although it was never triggered).
Recently I bought the Aeotec Alarm 6, and I included in my z-wave network like a charm, without any problems (S2 included).
Now I am unable to create a recipe to make the alarm sound when the door is open.
I see all the accessories in the "elements" view, but when I create a IF/THEN Recipe I can use the door sensor open in the IF part, but only can Send Notification by e-mail in the THEN part. The alarm accesorio is shown in the IF part as binary sensors which they are not...
Any clue on this?
Thanks in advance
Can't trigger Aeotec Alarm 6
Re: Can't trigger Aeotec Alarm 6
This is a known problem. We will fix it soon. You can workaround it by executing /JS/Run/controller.devices.get("VDEV").set("metrics:probeType", "alarm") for all devices that looks like alarms. VDEV should substitute the device ID that appers when you put your mouse on the gear on the device widget.
We will fix it in v3.0.1
Thank you very much!!
Sorry I missed your answer as I finished my holidays
I've tried,jor URL, but didn't work, I get an error:
As I guess my device ID is 16:
But I also tried with 16.0
Maybe I'm doing something wrong...
This is what I entered in the address box:TypeError: Cannot read property 'set' of null
http://192.168.1.12:8083/JS/Run/controller.devices.get("16").set("metrics:probeType","alarm")But I also tried with 16.0
- Captura de pantalla 2019-09-22 a las 11.35.03.png (48.93 KiB) Viewed 24854 times
Ok... My fault with the VDEV... It was not something like 16 but something like "ZWayVDev_zway_16-5-113-8-10-A"
Now I get a error-free answer:
will make some tests now!
Thank you!
"creationTime": 1566986272,
"creatorId": 1,
"customIcons": {},
"deviceType": "sensorBinary",
"h": -1684480381,
"hasHistory": false,
"id": "ZWayVDev_zway_16-5-113-8-10-A",
"location": 0,
"locationName": "globalRoom",
"metrics": {
"icon": "alarm",
"level": "off",
"title": "Power Management Alarm (16.5)",
"isFailed": false,
"probeType": "alarm"
"nodeId": 16,
"order": {
"rooms": 0,
"elements": 0,
"dashboard": 0
"permanently_hidden": false,
"probeType": "alarm_power",
"tags": [],
"visibility": true,
"updateTime": 1569147474
}Thank you!
I keep on trying but I see no way to trigger the alarm.
Actually I updated to 3.0.1 with the Raspbian package from official page: https://storage.z-wave.me/z-way-server/index_.php and still the same issue.
I think the error is in
As it's not a sensorBinary, but I've tried switchBinary and some others with no luck...
Any ideas?
"deviceType": "sensorBinary",Any ideas?
Found something promising: https://aeotec.freshdesk.com/support/so ... z-wave-me-
shreyaraina
- Contact:
Great Post
