Reporting bugs
Reporting bugs
When reporting bugs please make sure to provide us minimal information about the issue you are facing. You can post issues here on the forum in a separate thread for each bug or on github
Here is the template for your bug report:
Please fill your bug report here
More info:
  • Z-Uno bootloader version:2.1.x (release version or test-ucxx?)
  • Security:none/S2/S0
  • Frequency:EU/US/RU/ANZ-BR/IN/CN/JP/KR/TW
  • Device included:yes/no
  • Device included securely by controller:yes/no
  • Controller:RaZberry/Z-Way/Fibaro HC2/Fibaro HCL/Vera/other
Connected peripherals:
Please add here a description, photo and/or schematics of your peripherals
Code:
If you can minimize your code to still reproduce the bug, please do it before reporting
your code here
Compiler log:
Please paster the compiler output
                     FIRMWARE DATA
        REVISION:02.15
        Z-WAVE FREQUENCY:RU
... (more lines up to)
        CHIP:1546 REVISION:4
Debug output:
Connect to UART0, enable Logging->UART0, open logging monitor and dump the output. Should look like:
0000:00 00
0010:A0 00
0011:A0 00
0012:A0 00
bletru
Z-Uno stops waking up
Post by bletru »
Z-Uno bootloader version:2.1.5
Security:none
Frequency:EU
Device included:yes
Device included securely by controller:no
Controller:PC with Ubuntu runnuing Domoticz, AEONTEC Z-Wave USB Stick (but it does not bother about the problem)
Hi there,
I have running the following code on the Z-Uno:
// LED pin number
// 13 pin - user LED of Z-Uno board
#define OTHER_PIN 21
// Potentiometer pin number
#define LDR_PIN A3
// channel number
#define ZUNO_CHANNEL_NUMBER_ONE   1
// Last saved potentiometer value
int giLastValue = 0;
int gbOn = true;
int giCounter = 0;
int giLightOn = 0;
int giLightOff = 0;
//ZUNO_SETUP_CHANNELS(ZUNO_SENSOR_MULTILEVEL_GENERAL_PURPOSE(getter));
      ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_LUMINANCE,
                             SENSOR_MULTILEVEL_SCALE_PERCENTAGE_VALUE,
                             SENSOR_MULTILEVEL_SIZE_TWO_BYTES,
                             SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS,
                             getter)
ZUNO_SETUP_SLEEPING_MODE(ZUNO_SLEEPING_MODE_SLEEPING); // SLEEPING MODE
// the setup routine runs once when you press reset:
void setup()
  Serial.begin (115200);
  pinMode (OTHER_PIN, OUTPUT);
  pinMode (LDR_PIN, INPUT);  // setup potentiometer pin as input
void loop ()
  int iValue = analogRead (LDR_PIN);
  if (iValue > 500)
    giLightOn++;
  else
    giLightOff++;
  if (giCounter % 10 == 0)
    gbOn = ! gbOn;
  if (gbOn)
    digitalWrite (OTHER_PIN, HIGH);
  else
    digitalWrite (OTHER_PIN, LOW);
  if (giCounter == 40)
    if (giLightOn > 30)
      giLastValue = 100;
    else if (giLightOff > 30)
      giLastValue = 0;
    else
      giLastValue = 50;
    zunoSendReport (ZUNO_CHANNEL_NUMBER_ONE);
    zunoSendDeviceToSleep ();
  giCounter++;
  delay (100);
byte getter (void)
  return giLastValue;
The wake up interval has been successfully set through the server to 960 seconds (16 minutes).
The first couple of times, the Z-Uno is waking up regularly and reporting correctly.
But after an non determinable number of reports it is not waking up anymore (see example attachement).
Even on pressing "reset" the Z-Uno reports once and goes back to sleep forever...
I have to factory reset the Z-Uno and reset the sleeping time of 960 s in order to get correct
behaviour back for some reports and than it fails again.
Could you help/check please?
Thanks and best regards
Christoph Malloth
kina500
Re: Z-Uno stops waking up
Post by kina500 »
Hi
Did you ver got any reply on this topic?
bletru wrote:
23 Oct 2019 12:39
Security:none
Frequency:EU
Device included:yes
Hi there,
// LED pin number
#define LDR_PIN A3
// channel number
int gbOn = true;
int giCounter = 0;
int giLightOn = 0;
int giLightOff = 0;
                             getter)
void setup()
void loop ()
  if (iValue > 500)
    giLightOn++;
  else
    giLightOff++;
    gbOn = ! gbOn;
  if (gbOn)
  else
    if (giLightOn > 30)
      giLastValue = 100;
      giLastValue = 0;
    else
      giLastValue = 50;
  giCounter++;
  delay (100);
byte getter (void)
  return giLastValue;
Christoph Malloth
