A S2 inclusion of this device keeps failing on CentralScene. Also a forced interview does not solve this.
Also other, new Fibaro devices (like the Walli series) fail on CentralScene
See attachment for log file of the FGBS-222 inclusion (S2 auth. mode)
centralScene Interview fails on Fibaro FGBS-222
- z-way-server.zip
- (79.32 KiB) Downloaded 872 times
Re: centralScene Interview fails on Fibaro FGBS-222
Running version R3.0.0 on Rpi/Stretch
We do not see anything critical in the log. Would be nice to get once the device in hands and make all the tests.
Same problem here. CentralScene interview fail and It generate notifications error when sensor polling (each 10 minutes):
Razberry V2
Rasbpberry 3B+
Raspbian Stretch
Zway v3.0.2
[2019-12-17 11:30:00.985] [I] [core] --- ZWayVDev_zway_5-0-50-2 performCommand processing: {"0":"update"}
[2019-12-17 11:30:00.986] [I] [zway] Adding job: Meter Get (v2/3)
[2019-12-17 11:30:00.990] [I] [core] --- ZWayVDev_zway_5-0-113-8-6-A performCommand processing: {"0":"update"}
[2019-12-17 11:30:00.990] [I] [zway] Adding job: Alarm Get (v3)
[2019-12-17 11:30:00.991] [I] [core] --- ZWayVDev_zway_5-0-113-8-8-A performCommand processing: {"0":"update"}
[2019-12-17 11:30:00.991] [D] [zway] Job 0x13 (Alarm Get (v3)): removing duplicate
[2019-12-17 11:30:00.993] [I] [core] --- ZWayVDev_zway_15-0-113-7-2-A performCommand processing: {"0":"update"}
[2019-12-17 11:30:00.993] [D] [zway] SENDING (cb 0x6e): ( 01 0E 00 13 05 07 56 01 32 01 10 D5 08 25 6E 02 )
[2019-12-17 11:30:00.994] [E] [zway] Can not find appropriate security scheme
[2019-12-17 11:30:00.994] [E] [zway] Error returned from __AlarmGet(zway, command, i, 0, NULL, NULL, NULL): Bad arguments (-1)
[2019-12-17 11:30:00.994] [I] [core] --- ZWayVDev_zway_15-0-49-1 performCommand processing: {"0":"update"}
[2019-12-17 11:30:00.995] [E] [zway] Can not find appropriate security scheme
[2019-12-17 11:30:00.995] [D] [zway] RECEIVED ACK
[2019-12-17 11:30:00.999] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-12-17 11:30:00.999] [D] [zway] SENT ACK
[2019-12-17 11:30:01.000] [D] [zway] Delivered to Z-Wave stack
[2019-12-17 11:30:01.007] [I] [core] Notification: error (module): Error durante la ejecución del comando: Error: Invalid argument
[2019-12-17 11:30:01.016] [I] [core] Error: Invalid argument
at Error (native)
at self.controller.devices.create.handler (automation/modules/ZWave/index.js:5156:14)
at _.extend.performCommand (automation/classes/VirtualDevice.js:316:25)
at automation/modules/SensorsPolling/index.js:82:9
at Array.forEach (native)
at AutomationController.onPoll (automation/modules/SensorsPolling/index.js:81:20)
at AutomationController.EventEmitter.emit (automation/lib/eventemitter2.js:311:33)
at automation/modules/Cron/index.js:138:27
at automation/modules/Cron/index.js:126:18
[2019-12-17 11:30:01.016] [I] [core] --- ZWayVDev_zway_15-1-113-7-2-A performCommand processing: {"0":"update"}
[2019-12-17 11:30:01.017] [E] [zway] Can not find appropriate security scheme
[2019-12-17 11:30:01.017] [E] [zway] Error returned from __AlarmGet(zway, command, i, 0, NULL, NULL, NULL): Bad arguments (-1)
[2019-12-17 11:30:01.017] [I] [core] --- ZWayVDev_zway_15-2-113-7-2-A performCommand processing: {"0":"update"}
[2019-12-17 11:30:01.018] [I] [core] --- ZWayVDev_zway_15-7-113-9-3-A performCommand processing: {"0":"update"}
[2019-12-17 11:30:01.018] [E] [zway] Can not find appropriate security scheme
[2019-12-17 11:30:01.018] [E] [zway] Error returned from __AlarmGet(zway, command, i, 0, NULL, NULL, NULL): Bad arguments (-1)
[2019-12-17 11:30:01.018] [I] [core] --- ZWayVDev_zway_15-3-49-15 performCommand processing: {"0":"update"}
[2019-12-17 11:30:01.019] [E] [zway] Can not find appropriate security scheme
[2019-12-17 11:30:01.024] [I] [core] Notification: error (module): Error durante la ejecución del comando: Error: Invalid argument
[2019-12-17 11:30:01.036] [I] [core] Error: Invalid argument
at Error (native)
[2019-12-17 11:30:01.036] [I] [core] --- ZWayVDev_zway_15-4-49-15 performCommand processing: {"0":"update"}
[2019-12-17 11:30:01.037] [E] [zway] Can not find appropriate security scheme
[2019-12-17 11:30:01.040] [I] [core] Notification: error (module): Error durante la ejecución del comando: Error: Invalid argument
[2019-12-17 11:30:01.047] [I] [core] Error: Invalid argument
at Error (native)
[2019-12-17 11:30:01.047] [I] [core] --- ZWayVDev_zway_15-7-49-1 performCommand processing: {"0":"update"}
[2019-12-17 11:30:01.048] [E] [zway] Can not find appropriate security scheme
[2019-12-17 11:30:01.051] [I] [core] Notification: error (module): Error durante la ejecución del comando: Error: Invalid argument
[2019-12-17 11:30:01.055] [D] [zway] RECEIVED: ( 01 18 00 13 6E 00 00 05 01 C4 7F 7F 7F 7F 01 01 03 07 00 00 00 02 01 00 00 5D )
[2019-12-17 11:30:01.056] [D] [zway] SENT ACK
[2019-12-17 11:30:01.056] [I] [zway] Job 0x13 (Meter Get (v2/3)): Delivered
[2019-12-17 11:30:01.056] [D] [zway] SendData Response with callback 0x6e received: received by recipient
[2019-12-17 11:30:01.056] [D] [zway] SETDATA devices.5.data.lastSendInternal = **********
[2019-12-17 11:30:01.057] [D] [zway] SETDATA devices.5.data.lastSend = 2415996 (0x0024dd7c)
[2019-12-17 11:30:01.057] [D] [zway] Job 0x13 (Meter Get (v2/3)): success
[2019-12-17 11:30:01.057] [I] [zway] Waiting for job reply: Meter Get (v2/3)
[2019-12-17 11:30:01.059] [I] [core] Error: Invalid argument
at Error (native)
[2019-12-17 11:30:01.124] [D] [zway] RECEIVED: ( 01 14 00 04 00 05 0C 56 01 32 02 21 32 00 00 00 00 6B B5 BF 00 F3 )
[2019-12-17 11:30:01.125] [D] [zway] SENT ACK
[2019-12-17 11:30:01.125] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2019-12-17 11:30:01.125] [D] [zway] Received reply on job (Meter Get (v2/3))
[2019-12-17 11:30:01.125] [D] [zway] SETDATA devices.5.instances.0.commandClasses.50.data.2.val = 0.000000
[2019-12-17 11:30:01.125] [D] [zway] SETDATA devices.5.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2019-12-17 11:30:01.125] [D] [zway] SETDATA devices.5.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2019-12-17 11:30:01.125] [D] [zway] SETDATA devices.5.instances.0.commandClasses.50.data.2 = Empty
[2019-12-17 11:30:01.125] [D] [zway] SENDING (cb 0x6f): ( 01 10 00 13 05 09 56 01 71 04 00 08 00 E2 EF 25 6F 9D )
[2019-12-17 11:30:01.134] [D] [zway] RECEIVED ACK
[2019-12-17 11:30:01.134] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-12-17 11:30:01.134] [D] [zway] SENT ACK
[2019-12-17 11:30:01.134] [D] [zway] Delivered to Z-Wave stack
[2019-12-17 11:30:01.248] [D] [zway] RECEIVED: ( 01 18 00 13 6F 00 00 0B 01 C4 7F 7F 7F 7F 01 01 03 07 00 00 00 02 01 00 00 52 )
[2019-12-17 11:30:01.248] [D] [zway] SENT ACK
[2019-12-17 11:30:01.248] [I] [zway] Job 0x13 (Alarm Get (v3)): Delivered
[2019-12-17 11:30:01.248] [D] [zway] SendData Response with callback 0x6f received: received by recipient
[2019-12-17 11:30:01.249] [D] [zway] SETDATA devices.5.data.lastSendInternal = **********
[2019-12-17 11:30:01.249] [D] [zway] SETDATA devices.5.data.lastSend = 2416014 (0x0024dd8e)
[2019-12-17 11:30:01.249] [D] [zway] Job 0x13 (Alarm Get (v3)): success
[2019-12-17 11:30:01.249] [I] [zway] Waiting for job reply: Alarm Get (v3)
[2019-12-17 11:30:01.323] [D] [zway] RECEIVED: ( 01 15 00 04 00 05 0D 56 01 71 05 00 00 00 FF 08 00 00 4D 11 C6 00 A8 )
[2019-12-17 11:30:01.324] [D] [zway] SENT ACK
[2019-12-17 11:30:01.324] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2019-12-17 11:30:01.324] [D] [zway] Received reply on job (Alarm Get (v3))
[2019-12-17 11:30:01.324] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.8.eventParameters = byte[0]
[2019-12-17 11:30:01.324] [D] [zway] ( zero-length buffer )
[2019-12-17 11:30:01.325] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.8.event = 0 (0x00000000)
[2019-12-17 11:30:01.326] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.8.eventString = ""
[2019-12-17 11:30:01.326] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.8.status = 255 (0x000000ff)
[2019-12-17 11:30:01.327] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.8 = Empty
[2019-12-17 11:30:03.224] [D] [zway] Job 0x13: deleted from queue
[2019-12-17 11:30:03.403] [D] [zway] Job 0x13: deleted from queue
[2019-12-17 11:30:09.528] [D] [zway] Job 0x3b: deleted from queue
Rasbpberry 3B+
Raspbian Stretch
Zway v3.0.2
- IMG-20191216.jpeg (152.7 KiB) Viewed 17944 times
Looks like FGBS-222 messed up security schemes. We need access to the device to test it.
Same problem with 'CentralScene' interview on FGR 223 - Fibaro roller shutter 3.
Can someone write bruteforce solution for me: http://ip:8083/JS/Run/zway.devices[24].....
But would be fine to solve incomplete interview normal way...
http://ip:8083/JS/Run/zway.devices[24]. ... wDone=true
But some button presses can be reported wrong in this case.
I can confirm this problem. I successfully included FGBS-222, the interview completed 100 %, used it for some days and then had to interrupt it’s power supply. After that the interview only reaches 99 % completion. The interview results show that “CentralScene” class doesn’t work.
Could you please share the log when it went to 99% ?
I chose "force interview" and attached the log file with the incomplete interview:
