Z-way server goes down spontaneously
GokMasE
Re: Z-way server goes down spontaneously
Post by GokMasE »
Ok, it is restarted but it is running extremely slow now, and at times is so busy that it temporarily seems to stop responding. Is it writing log data to both PuTTY console window and to a file? Is there anything I can do to make logging affect performance a bit less by any chance?
/J
You can redirect the full output to a file. Writing to putty console is very slow. This file will be our debug log
GokMasE
Post by GokMasE »
Starting it with the exact command line you suggested writes a lot of numbers to console. How exactly do I redirect to only file?
add this at the end 1>/tmp/z-way.log 2>&1
and if you want to leave the console then first execute "screen" (install if needed) and then you can even close the terminal window. To get it back connect and run "screen -rx". This will allow to detach the console keeping the program running
GokMasE
Post by GokMasE »
I am probably doing something wrong here, but after a reboot it turns out I am unable to stop the z-way-server by issuing:
pi@raspberrypi:~ $ sudo /etc/init.d/z-way-server stop
If I try and run "top" right after attempting to stop the server by using the line above, I still see z-way-server as active process. Since z-way-server in this case had been automatically started upon rebooting, gdb should not be in play at all. Is there anything else that could prevent me from stopping the z-way-server here?
/J
hm... this is a grace exit. try to kill the process ungracefully and then run the debug:
LD_LIBRARY_PATH=libs ./z-way-server -l 0 -L - 1>/tmp/z-way.log 2>&1
GokMasE
Post by GokMasE »
Ok, by going with this I can finally kill the already running z-way-server:
sudo kill -9 <pid>
Then I try to start the server again this way:
pi@raspberrypi:/opt/z-way-server $ LD_LIBRARY_PATH=libs ./z-way-server -l 0 -L - 1>/tmp/z-way.log 2>&1
Then the server tries to start and logs for a bit, and then halts after this has been written to log:
>> I U 0
>> First free 0x7d0f0
>> Block 0x7d0e0
  X 0x7d0e0  . 0x7d0f0  . 0x7d100  . 0x7d110  . 0x7d120  . 0x7d130  . 0x7d140  . 0x7d150  . 0x7d160  . 0x7d170  . 0x7d180  . 0x7d190  . 0x7d1a0  . 0x7d1b0  . 0x7d1c0  . 0x7d1d0
  . 0x7d1e0  . 0x7d1f0  . 0x7d200  . 0x7d210  . 0x7d220  . 0x7d230  . 0x7d240  . 0x7d250  . 0x7d260  . 0x7d270  . 0x7d280  . 0x7d290  . 0x7d2a0  . 0x7d2b0  . 0x7d2c0  . 0x7d2d0
  . 0x7d2e0  . 0x7d2f0  . 0x7d300  . 0x7d310  . 0x7d320  . 0x7d330  . 0x7d340  . 0x7d350  . 0x7d360  . 0x7d370  . 0x7d380  . 0x7d390  . 0x7d3a0  . 0x7d3b0  . 0x7d3c0  . 0x7d3d0
  . 0x7d3e0  . 0x7d3f0  . 0x7d400  . 0x7d410  . 0x7d420  . 0x7d430  . 0x7d440  . 0x7d450  . 0x7d460  . 0x7d470  . 0x7d480  . 0x7d490  . 0x7d4a0  . 0x7d4b0  . 0x7d4c0  . 0x7d4d0
  . 0x7d4e0  . 0x7d4f0  . 0x7d500  . 0x7d510  . 0x7d520  . 0x7d530  . 0x7d540  . 0x7d550  . 0x7d560  . 0x7d570  . 0x7d580  . 0x7d590  . 0x7d5a0  . 0x7d5b0  . 0x7d5c0  . 0x7d5d0
  . 0x7d5e0  . 0x7d5f0  . 0x7d600  . 0x7d610  . 0x7d620  . 0x7d630  . 0x7d640  . 0x7d650  . 0x7d660  . 0x7d670  . 0x7d680  . 0x7d690  . 0x7d6a0  . 0x7d6b0  . 0x7d6c0  . 0x7d6d0
  . 0x7d6e0  . 0x7d6f0  . 0x7d700  . 0x7d710  . 0x7d720  . 0x7d730  . 0x7d740  . 0x7d750  . 0x7d760  . 0x7d770  . 0x7d780  . 0x7d790  . 0x7d7a0  . 0x7d7b0  . 0x7d7c0  . 0x7d7d0
  . 0x7d7e0  . 0x7d7f0  . 0x7d800  . 0x7d810  . 0x7d820  . 0x7d830  . 0x7d840  . 0x7d850  . 0x7d860  . 0x7d870  . 0x7d880  . 0x7d890  . 0x7d8a0  . 0x7d8b0  . 0x7d8c0  . 0x7d8d0
  . 0x7d8e0  . 0x7d8f0  . 0x7d900  . 0x7d910  . 0x7d920  . 0x7d930  . 0x7d940  . 0x7d950  . 0x7d960  . 0x7d970  . 0x7d980  . 0x7d990  . 0x7d9a0  . 0x7d9b0  . 0x7d9c0  . 0x7d9d0
  . 0x7d9e0  . 0x7d9f0  . 0x7da00  . 0x7da10  . 0x7da20  . 0x7da30  . 0x7da40  . 0x7da50  . 0x7da60  . 0x7da70  . 0x7da80  . 0x7da90  . 0x7daa0  . 0x7dab0  . 0x7dac0  . 0x7dad0
  . 0x7dae0  . 0x7daf0  . 0x7db00  . 0x7db10  . 0x7db20  . 0x7db30  . 0x7db40  . 0x7db50  . 0x7db60  . 0x7db70  . 0x7db80  . 0x7db90  . 0x7dba0  . 0x7dbb0  . 0x7dbc0  . 0x7dbd0
  . 0x7dbe0  . 0x7dbf0  . 0x7dc00  . 0x7dc10  . 0x7dc20  . 0x7dc30  . 0x7dc40  . 0x7dc50  . 0x7dc60  . 0x7dc70  . 0x7dc80  . 0x7dc90  . 0x7dca0  . 0x7dcb0  . 0x7dcc0  . 0x7dcd0
  . 0x7dce0  . 0x7dcf0  . 0x7dd00  . 0x7dd10  . 0x7dd20  . 0x7dd30  . 0x7dd40  . 0x7dd50  . 0x7dd60  . 0x7dd70  . 0x7dd80  . 0x7dd90  . 0x7dda0  . 0x7ddb0  . 0x7ddc0  . 0x7ddd0
  . 0x7dde0  . 0x7ddf0  . 0x7de00  . 0x7de10  . 0x7de20  . 0x7de30  . 0x7de40  . 0x7de50  . 0x7de60  . 0x7de70  . 0x7de80  . 0x7de90  . 0x7dea0  . 0x7deb0  . 0x7dec0  . 0x7ded0
  . 0x7dee0  . 0x7def0  . 0x7df00  . 0x7df10  . 0x7df20  . 0x7df30  . 0x7df40  . 0x7df50  . 0x7df60  . 0x7df70  . 0x7df80  . 0x7df90  . 0x7dfa0  . 0x7dfb0  . 0x7dfc0  . 0x7dfd0
  . 0x7dfe0  . 0x7dff0  . 0x7e000  . 0x7e010  . 0x7e020  . 0x7e030  . 0x7e040  . 0x7e050  . 0x7e060  . 0x7e070  . 0x7e080  . 0x7e090  . 0x7e0a0  . 0x7e0b0  . 0x7e0c0  . 0x7e0d0
[2020-03-12 23:02:27.566] [I] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2020-03-12 23:02:27.569] [I] [core] Executing script: // Comon utilities and functions ...
[2020-03-12 23:02:27.577] [I] [core] Executing script: // This script transforms old formats to new ...
[2020-03-12 23:02:27.645] [I] [core] Error: can not write back config.json to storage:  Error: Permission denied
[2020-03-12 23:02:27.657] [I] [core] Error: can not write userSkins.json to storage:  Error: Permission denied
>> I U 1
>> First free 0x7d100
>> Block 0x7d0e0
  X 0x7d0e0  X 0x7d0f0  . 0x7d100  . 0x7d110  . 0x7d120  . 0x7d130  . 0x7d140  . 0x7d150  . 0x7d160  . 0x7d170  . 0x7d180  . 0x7d190  . 0x7d1a0  . 0x7d1b0  . 0x7d1c0  . 0x7d1d0
>> I U 2
>> First free 0x7d110
>> Block 0x7d0e0
  X 0x7d0e0  X 0x7d0f0  X 0x7d100  . 0x7d110  . 0x7d120  . 0x7d130  . 0x7d140  . 0x7d150  . 0x7d160  . 0x7d170  . 0x7d180  . 0x7d190  . 0x7d1a0  . 0x7d1b0  . 0x7d1c0  . 0x7d1d0
>> I U 3
>> First free 0x7d120
>> Block 0x7d0e0
  X 0x7d0e0  X 0x7d0f0  X 0x7d100  X 0x7d110  . 0x7d120  . 0x7d130  . 0x7d140  . 0x7d150  . 0x7d160  . 0x7d170  . 0x7d180  . 0x7d190  . 0x7d1a0  . 0x7d1b0  . 0x7d1c0  . 0x7d1d0
[2020-03-12 23:02:27.675] [E] [core] result: Error: Error: Permission denied
    at Error (native)
    at automation/updateBackendConfig.js:663:3
    at automation/updateBackendConfig.js:665:3
    at automation/main.js:23:1
[2020-03-12 23:02:27.677] [E] [core] result: Error: Error: Uncaught Error: Permission denied
    at Error (native)
>> D U 4
>> First free 0x7d0f0
>> Block 0x7d0e0
  X 0x7d0e0  . 0x7d0f0  X 0x7d100  X 0x7d110  . 0x7d120  . 0x7d130  . 0x7d140  . 0x7d150  . 0x7d160  . 0x7d170  . 0x7d180  . 0x7d190  . 0x7d1a0  . 0x7d1b0  . 0x7d1c0  . 0x7d1d0
>> D U 3
>> First free 0x7d100
>> Block 0x7d0e0
  X 0x7d0e0  . 0x7d0f0  . 0x7d100  X 0x7d110  . 0x7d120  . 0x7d130  . 0x7d140  . 0x7d150  . 0x7d160  . 0x7d170  . 0x7d180  . 0x7d190  . 0x7d1a0  . 0x7d1b0  . 0x7d1c0  . 0x7d1d0
>> D U 2
>> First free 0x7d110
>> Block 0x7d0e0
If I try to run it with "sudo" added, the server seems to start up and keep on running this time, but writing to the z-way.log file VERY fast, it builded up >100mb in notime. However, in this session I got no response at all from the server when trying to access http://192.168.1.195:8083/ -it seems fully locked up/unresponsive.
I terminated the session after the log file went beyond 275mb in size and there was still no response on http://192.168.1.195:8083/. A quick look in the resulting log shows that after the init section, the only thing written seems to be HEX data. The heading of the last HEX data written before termination was:
>> I U 89
>> First free 0x7240a990
>> Block 0x7240a3f0
Is this expected? Should I keep the process running for even longer?
Regards,
/J
This is really interesting... The huge dump of hex data happens when a new persistent object is created in JS. Persistent means there is a referance to this JS object from C because the task went in background (socket created, http request in progress). In normal operation you should never get so many of them, because then the task is over, the object is garbage collected. This means objects leaks in your case - they are created and never destructed or they are created faster than finishes.
In my system for example the number of object is less than 5. Sometimes 7. But never 89!
If you compare the log, can you see what relates to those objects?
Please send me the gzipped log by mail. Would be probably nice to get hands on your Pi by SSH. If remote support was enabled, we can access it. Please provide the password for pi user. If this is acceptable for you...
GokMasE
Post by GokMasE »
Hm, indeed interesting! I am currently at work so can't give you any answers or send anything until later this evening.
The fact that these JS objects are created faster than they are processed/removed (or never removed at all) is especially intriguing, and my hunch would be that it could be the Fibaro switch/energy meter that is causing this. I noticed that under some circumstances it sends quite a lot of sensor data. I guess a peek in the z-way-server log later today could possibly hold some clues..
I suppose that the log you're interested in is the "normal" z-way-server log? Or do you also want the z-way.log with all the hex data?
And can I mail files that big to your email account or should they be uploaded somewhere?
Regards,
/J
