Firmware upgrade brick?
MrRusch
Post by MrRusch »
I listened to recorded webinar today, used the token to find upgrade and proceeded assuming that my device ZMEERAZ2 Rev.2.1 would be fine as I purchased it relatively recently.
However, after upgrading firmware the device seems to be completely dead.
z-way-server.log (attached) shows the process seemingly succeeding, ordering a soft reset and terminating the z-wave binding,
[2020-05-19 21:45:39.722] [I] [zway] Removing job: Soft reset
[2020-05-19 21:45:39.733] [D] [zway] Worker thread exit point
[2020-05-19 21:45:39.734] [D] [zway] Worker thread successfully finished
[2020-05-19 21:45:39.734] [I] [core] Terminating Z-Wave binding
..only to realize it cant find it again,
[2020-05-19 21:45:41.873] [C] [zway] data access without a lock
[2020-05-19 21:45:41.873] [E] [zway] Node 15:0 CC Security: No controller device found
[2020-05-19 21:45:42.003] [I] [core] Trying to restart Z-Wave binding (zway) in 10 seconds
..ending finally with,
[2020-05-19 21:46:34.996] [D] [zway] Opened device: /dev/ttyAMA0
[2020-05-19 21:46:34.996] [D] [zway] Worker thread successfully created
[2020-05-19 21:46:34.996] [D] [zway] Worker thread entry point
[2020-05-19 21:46:34.996] [I] [zway] Adding job: Get controller info and supported function classes
[2020-05-19 21:46:35.006] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2020-05-19 21:46:35.208] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2020-05-19 21:46:35.208] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2020-05-19 21:46:35.410] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2020-05-19 21:46:35.410] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2020-05-19 21:46:35.612] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2020-05-19 21:46:35.612] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2020-05-19 21:46:35.612] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2020-05-19 21:46:35.612] [C] [zway] Get Serial API Capabilities returned zero.
[2020-05-19 21:46:35.613] [I] [zway] Removing job: Get controller info and supported function classes
[2020-05-19 21:46:35.623] [D] [zway] Worker thread exit point
[2020-05-19 21:46:35.623] [D] [zway] Worker thread successfully finished
[2020-05-19 21:46:35.634] [I] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2020-05-19 21:46:35.649] [I] [core] Error: Bad data - communication failed
[2020-05-19 21:46:35.651] [I] [core] Tried 5 times without success. Stopping tries.
[2020-05-19 21:46:35.656] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
ZMESerialUpdater just keeps ticking away with (-->) apparently unable to open the port.
I have done multiple complete power cycles of RPI and am stuck.
Any ideas?
upgrade.rar
(272.45 KiB) Downloaded 693 times
MrRusch
Re: Firmware upgrade brick?
Post by MrRusch »
This seems to be a perfect duplicate,
https://forum.z-wave.me/viewtopic.php?f ... ro.#p84723
My leds seem pretty strong, not sure what it used to look like.
micky1500
Post by micky1500 »
Think you answered your own question.
I'm sure Serguei said the blue ones were suspect in the Webinar (bad manufacture batch - fails upgrade).
https://forum.z-wave.me/viewtopic.php?f ... lue#p81821
Maybe Poltos will give some advice.
Correct, blue boards are affected by this issue. If both LEDs lid faintly, it is dead. Please swap it in your shop for free.
MrRusch
Post by MrRusch »
OK, will do.
