logrotate z-way-server has wrong file mode
Re: logrotate z-way-server has wrong file mode
but there is a postinst that should change the mode to 0644. So i'm surprised...
May be this is because you don't use .deb but extract it manually?
I was just curious and looked in the .deb file.
I upgraded from 3.0.5 to 3.0.6 using z-way web UI, I didn't do anything manually.
Raspi 4(Buster), Zwave Version 3.1.2
Hm.. if you force install of this deb packet again, will permissions remain incorrect?
Maybe someone else can try.
I have already applied the work around. and currently I have a working system.
Just fingers crossed it still works with 3.0.7
Great. My log file just exceded 2GB. Tried 'sudo chmod....' command.
Hope this will solve the problem. But when?
This morning I checked and new log file was created.
This was not solved in 3.0.6 version ?
Hm,.. interesting - we can not reproduce this issue. Do you have a newly installed system? Or it was an upgrade?
I ran a test and it failed if the upgrade was done using the Webui.
I installed v3.0.6 on a Clean Raspberry/Buster. That installed with the correct chmod settings.
Ran the upgrade process (3.0.6) via Chrome-Webui Configuration-Management-FirmwareUpgrade - -
It Sets the WRONG chmod settings.
but running the ssh upgrade sudo dpkg -i z-way-3.0.6_armhf.deb
it sets the correct chmod settings.
Thank you, looks I found the issue!
