hi
my virtual thermostat cannot stand xx.5
only whole numbers 22 23 24 not 22.5 23.5 24.5
I run 3.0.6 on raspberry
cb
virtual thermostat only whole numbers
Re: virtual thermostat only whole numbers
Will check it.
Hi
This is not fix jet, I now use 3.1.1
and problem with virtual thermostat is still xx,5 can't be set only whole numbers
I'll make sure this is fixed in upcoming releases
for the time being, you can change it directly in the configuration file
![Smile :)](./images/smilies/icon_e_smile.gif)
1. stop service:
sudo /etc/init.d/z-way-server stop
2. Open config file:
locations: /opt/z-way-server/automation/storage/configjson[some numbers].json
3. Find section with name of your thermostat, mine is "Bedroom heater") and add "step: 1", also you can change min and max value:
"ZWayVDev_zway_18-0-67-1": {
"deviceType": "thermostat",
"probeType": "thermostat_set_point",
"metrics": {
"scaleTitle": "°C",
"level": 21,
"min": 10,
"max": 28,
"step": 1,
"icon": "thermostat",
"title": "Bedroom heater",
"isFailed": false,
"modificationTime": 1601801583,
"lastLevel": 21
sudo /etc/init.d/z-way-server start
