I have some problem to integrate my brand new qubino mini dimmer. The interview hangs at 67 % at Security/Security S2. And now I am note able to exclude to device to start over. in expert UI it is not listed under failed devices. and in normal mode i get an error while trying to force remove.
I am using v3.0.6.
Any hints? thx
Problem with Qubino mini Dimmer
login@huegli.co
Re: Problem with Qubino mini Dimmer
The issue is getting stranger. I could now exclude and reinclude the device and the interview is at 100%. But i cant do anything with the device. There is absolutely no function. It shows " The device works properly". But i am not able to change properties or even choose a device description...
