Hi, by mistake I masked all events from type "connection lost", by the way these events disappear from the z-way-server.log too
can anybody tell me how to re-enable events masked by type?
need help to unmask type specific events
Re: need help to unmask type specific events
Looks like the UI is missing this. We have created a ticket for it.
Meanwhile stop Z-Way, open config,json on the filesystem and search for hide_single_device_events. Edit the value of this field and restart Z-Way back.
Thanks for your response,
I changed in config,json "hide_single_device_events": [], --> "hide_single_device_events": false,
I now have the "[core] Notification: error (connection): Connection lost to Z-Wave device ID: 9" in the log, but neither events in the event gui, nor unfortunately a way to get the event watcher triggering according to
https://forum.z-wave.me/viewtopic.php?t=25726
which worked perfectly before.
As I workaround I now use SEC analyzing the log and the code device app "to get value"
Do you have another hint?
[] -> false is wrong. [] means it is not the correct value - you need to find another one. Please send this file or check yourself similar fields around.
Okay, mysterious, false appeared to be the appropriate value regarding the other parameters ....
I joined the file (zipped for upload reasons)
- config.zip
- (2.73 KiB) Downloaded 350 times
"hide_single_device_events": [] should be the correct way to reset it. Make sure you are fixing this in the correct (may be all) profile
I changed again for "hide_single_device_events": [] in all (2) profiles, rebooted and tested by powering off the z-wave switch device. No notification about connection lost.
My sec + code device (log tracking with sec -> value in a semaphore file -> red by a zway code device) workaround works very well.
If its to give mor information for the ticket you created on 9th November I ll be ready to continue with you on this, otherwise I get all I need by the workaround.
Thank you
Thank you
