MQTT plugin gets its settings lost on restart
piet66
Re: MQTT plugin gets its settings lost on restart
Post by piet66 »
Uploaded now to store. I hope it's useful.
Name: MxMQTT Subscriber
It's a beta. That means, it's working for me, but I have not the time to test everything.
Note: It's necessary to download and run the latest version of MxBaseModule first.
We are working on our pretty generic module that will fit most of customers. May be we take some ideas from you :)
You are always welcome to contribute!
Sorry for being so late with the native implementation, but better now than never ;)
We did so much in improving Z-Way and adding new features this spring that we are even stuck without new releases as we have so many things to tests first...
piet66
Post by piet66 »
@PoltoS
When we receive and send data via MQTT there might be also non-numerical values like booleans, strings and dates/times.
For these we should have appropriate device widgets for handling. Can you please think about providing such widgets?
We would need:
- a select box widget for strings
- a date and/or time picker
There is device type *text* for strings (can be also used for date), *sensorBinary* for boolean. Those are read-only. To make them selectable one need to add new device types and UI for them.
This part is open-source, you can contrinute ;) Not sure if we can fit it in our tought schedule.... Our TODO consists of more than 200 feature requests or bug reports
piet66
Post by piet66 »
For only read-only output you don't need a special widget. sensorMultilevel can display any data format.
To make them selectable, one need to add new device types and UI for them. This part is open-source, you can contribute
Can you provide an understandable recipe?
You need to look in:
https://github.com/Z-Wave-Me/zwave-smar ... -widget.js
https://github.com/Z-Wave-Me/zwave-smar ... ts/widgets
But please keep in mind that we are reworking the UI and hence this work will have to be done again by you. So may be wait for august when we deploy the new one for public
sofakng
Post by sofakng »
I'm also looking forward to built-in MQTT support!
