After upgrade to 3.2.0 API is not working correctly ?
vinisz
Post by vinisz »
Not sure if this is 100% API, but I use node-red (with the zway node) and after the upgrade to 3.2.0 I'm able to send data from node-red to Zway but no data from zway is arriving at node-red anymore.
Also opened issue for the node-red zway node developper here : https://github.com/bkorda/node-red-cont ... /issues/10
Maybe you can work together to see why this is not working anymore.
Re: After upgrade to 3.2.0 API is not working correctly ?
We are ready to help, but we don't know which API is used by this intergration
vinisz
Post by vinisz »
StevenD wrote:
03 Sep 2021 19:50
vinisz wrote:
02 Sep 2021 18:11
You need to wait for the bug to be solved.
I can't wait very long, the house is now quite "malfunctioning" , thats why I also ask on how to roll back.
As for the node-red binding, stupid thing is that when I restart zway, it receives data, for like 1 minute, and then it stops (either on z-way or node-red node side)
sonalford
Post by sonalford »
vinisz wrote:
02 Sep 2021 18:11
I don't understand the problem you give to find a solution for this, I also don't know what API is used.
We have checked, node-red is using Websocket API. We have provided a fix for the node-red integration. Hope it will be approved soon
vinisz
Post by vinisz »
Sounds good, thanks
You can test it - it alters three files only and requires reconfiguration of your app to tokens instead of login/pass
