on v 3.2.2 for my Fibaro FGS 222 was an ZDDX Description Found.
On new Version v 3.2.3 for the same Device not ?
Is there an Reason ?
Version 3.2.3
Version 3.2.2
ZDDX for FGS 222
ZDDX for FGS 222
Greetings from germany
Jörg
Jörg
Re: ZDDX for FGS 222
Sure you have the database in /opt/z-way-server/ZDDX/ ?
yes, then Description for other Devices are found.
This is the Created File with ZDDX Creator
Wich Tags are Used to find the Description ?
Jörg
Jörg
on an Comet Heating Thermostat I can Select the Device Description, but after Save Buton, the Description is not Save.
On Version 3.2.2 it works fine
- comet3.2.2.png (79.09 KiB) Viewed 9612 times
Jörg
Jörg
Please let me check in your ui. Please send the credentials in PM or on support with a link to this post
I have send you an private message
Greetings jörg
Greetings jörg
Jörg
Jörg
Thanks for the access. The problem is in the update of python to python3. Please go in /opt/z-way-server/ZDDX and run
If you don't have python2.7, open the MakeIndex.py and remove all encounters of
save and run .
python2.7 MakeIndex.pyCode: Select all
.encode('utf-8')Code: Select all
python3 MakeIndex.pyRe: ZDDX for FGS 222
Hello Poltos,
thanks a Lot. It works fine.
There are any Incorrect Value in ZDDX ( Sample FGS-212, 665-010f-0400-100a-03-03-2a-02-01.xml )
- Missing ProductCode
- wrong Description
- Missing Image
On my Local i have correct this.
Who correct this on general Database ?
Greetings from Germany
Jörg
- wrong Description
- Missing Image
Jörg
Jörg
Jörg
You can send it us, we fix. on support (tag me, please)
Hello Polto,
so we do.
so we do.
Jörg
Jörg
