ZDDX for FGS 222
J.nissen
ZDDX for FGS 222
Post by J.nissen »
on v 3.2.2 for my Fibaro FGS 222 was an ZDDX Description Found.
On new Version v 3.2.3 for the same Device not ?
Is there an Reason ?
Version 3.2.3
Version 3.2.2
Greetings from germany
Jörg
Re: ZDDX for FGS 222
Sure you have the database in /opt/z-way-server/ZDDX/ ?
J.nissen
Post by J.nissen »
yes, then Description for other Devices are found.
This is the Created File with ZDDX Creator
Wich Tags are Used to find the Description ?
Jörg
J.nissen
Post by J.nissen »
on an Comet Heating Thermostat I can Select the Device Description, but after Save Buton, the Description is not Save.
On Version 3.2.2 it works fine
Jörg
Please let me check in your ui. Please send the credentials in PM or on support with a link to this post
J.nissen
Post by J.nissen »
I have send you an private message
Greetings jörg
Jörg
Thanks for the access. The problem is in the update of python to python3. Please go in /opt/z-way-server/ZDDX and run
python2.7 MakeIndex.py
If you don't have python2.7, open the MakeIndex.py and remove all encounters of
.encode('utf-8')
save and run
python3 MakeIndex.py
J.nissen
Post by J.nissen »
Hello Poltos,
thanks a Lot. It works fine.
There are any Incorrect Value in ZDDX ( Sample FGS-212, 665-010f-0400-100a-03-03-2a-02-01.xml )
- Missing ProductCode
- wrong Description
- Missing Image
On my Local i have correct this.
Who correct this on general Database ?
Greetings from Germany
Jörg
Jörg
You can send it us, we fix. on support (tag me, please)
J.nissen
Post by J.nissen »
Hello Polto,
so we do.
Jörg
