RaZberry 7 Pro Firmware
Re: RaZberry 7 Pro Firmware
Please show the Z-Way log
Here you go.... (this is right after start of the Rpi, log file was removed before restart)
seattleneil
Based on the log file, it's clear your controller is definitely not happy:
[2022-04-19 12:07:52.611] [D] [zway] Opened device: /dev/ttyAMA0
[2022-04-19 12:07:52.611] [i/o] Setting port speed to 115200
[2022-04-19 12:07:52.611] [D] [zway] Worker thread successfully created
[2022-04-19 12:07:52.611] [D] [zway] Worker thread entry point
[2022-04-19 12:07:52.612] [zway] Adding job: Get controller info and supported function classes
[2022-04-19 12:07:52.622] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2022-04-19 12:07:52.823] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2022-04-19 12:07:52.823] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2022-04-19 12:07:53.025] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2022-04-19 12:07:53.025] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2022-04-19 12:07:53.226] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2022-04-19 12:07:53.226] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
There are several possible explanations, from an unresponsive controller, dead controller, incorrect/poor seating of the controller and /dev/ttyAMA0 serial port contention. To troubleshoot the problem, do a full controller reset by fully powering off your Pi. Don't just do a reboot, remove power, confirm the controller card is installed correctly, and then re-apply power. There are 2 LEDs on the controller - did both LEDs turn on and then turn off after 2 seconds? If not, then you probably have a dead controller. @PoltoS might have suggestions on what to do if the LEDs do not turn on and then turn off.
With the Pi re-booted, check the z-way-server log file to see if you're still getting No ACK timeout errors shortly after you see: "Opened device: /dev/ttyAMA0". With luck, you had an unresponsive controller and power-cycling the controller solved the problem. If you still see the No ACK error messages, then a possible cause is some other process is trying to use the serial port. Run: "sudo lsof -n | grep AMA0". You should see a single z-way process (with multiple threads). If the lsof command shows another process, you have a configuration error (e.g., bluetooth or console port trying to use the serial port) that you will need to fix ( e.g., /boot/config.txt or /boot/cmdline.txt has to be updated).
Thanks for all these tips, I checked all of them.
What I can see is when I " switch" controller to the PRO7 is this:
pi@raspberrypi:~ $ sudo lsof -n | grep AMA0
z-way-ser 391 root 7u CHR 204,64 0t 0 136 /dev/ttyAMA0
z-way-ser 391 515 Optimizin root 7u CHR 204,64 0t 0 136 /dev/ttyAMA0
z-way-ser 391 516 v8:Sweepe root 7u CHR 204,64 0t 0 136 /dev/ttyAMA0
z-way-ser 391 517 v8:Sweepe root 7u CHR 204,64 0t 0 136 /dev/ttyAMA0
z-way-ser 391 518 v8:Sweepe root 7u CHR 204,64 0t 0 136 /dev/ttyAMA0
z-way-ser 391 519 v8:Sweepe root 7u CHR 204,64 0t 0 136 /dev/ttyAMA0
z-way-ser 391 520 zway/core root 7u CHR 204,64 0t 0 136 /dev/ttyAMA0
z-way-ser 391 539 zway/webs root 7u CHR 204,64 0t 0 136 /dev/ttyAMA0
z-way-ser 391 540 zway/time root 7u CHR 204,64 0t 0 136 /dev/ttyAMA0
z-way-ser 391 2304 zway/dev/ root 7u CHR 204,64 0t 0 136 /dev/ttyAMA0
So, you can see it tries (for a second or 3, 4) and then, when I do the grep again, nothing....
After checking connections and powercycle, I do see the 2 leds going on and then off, so that looks good.
It cannot be that the old controller (UZB on USB) is in the way right ?
Can you check please if the chip heats up? Can you hold the finger on it?
How can I get which firmware version my 7 pro currently have?
Z-Way shows:
Is that right place to look at?
Z-Way shows:
Firmware version v3.2.3
UI version v1.13.5
That is the Z-Way software. Go into Expert, Network, Controller Info and then click Firmware Update near the bottom.
Yes ;(
Please ask your shop for a replacement
