Cannot include devices S2/S0 on RaZberry 7 Pro
n-gauge
Post by n-gauge »
Inclusion in Expert UI of S0-devices in 'Secure S2 & S0' always fails, I get the message 'Security S0 timeout'.
Inclusion of the same device in Standard UI succeeds, but with failed Security interview.
This happens with all my devices.
The problem has been the same whether using FW 7.05, 7.13 or 7.21 and Z-Way 3.2.3 or 4.0.0. I'm currently running FW7.21 and Z-way 4.0.0.
To test if it may be a software problem I reinstalled my old RaZberry 2 with FW5.39, still running Z-Way 4.0.0. No problems at all with inclusion and security interview.
Somebody else had/has this problem?
Should I assume the RaZ-7 is defective? Or is it a FW-issue? (3 generations FW with same problem seems unlikely, though)
The problem has to be with RaZ-7, as everything works fine with the RaZ-2, the rest of the HW/SW-configuration being exactly the same.
Re: Cannot include devices S2/S0 on RaZberry 7 Pro
Please send us the inclusion log via help.z-wave.me. We will check it.
harre
Post by harre »
I have included me device with node 91 and it got "s0 timeout" message. I then excluded it and reincluded.
Now it got id 92 and also timeout.
Logs are here:
https://www.dropbox.com/s/l0lqkysj8ux0o ... 2Clog?dl=0
harre
Post by harre »
This problem have been there for a while. It will need 5-6 include/exclude retries to get it working.
We will make a fix soon in the firmware. It will be a workaround since the root is in the SiLabs SDK: it makes hangs for more than 8 seconds in read/write operations and gets kicked by the WatchDog at the end. Please wait for the next version of RaZberry firmware
harre
Post by harre »
21 Dec 2022 16:51
Thank you!
I'm happy to beta test anything as I have a few devices waiting for inclusion because I don't want to retry inclusion for like 5-10 times per device.
harre
Post by harre »
21 Dec 2022 16:51
I have installed the new update, but I still get same issue.
Or will the updated firmware come in another update?
lanbrown
Post by lanbrown »
The current firmware is 7.28 / 07.17.02.01 SDK 7.17.02.
If that is what you upgraded to, then that was released long before the post from PoltoS on 12/21 talking about a future firmware upgrade.
harre
Post by harre »
alright, I see I have fw 7.28 so I'll wait for the update then.
lanbrown
Post by lanbrown »
2022-03-12	7.6		7.13	Update firmware from 7.5 to 7.13 (SDK 7.17.01.02) NB! Requires Z-Way v3.2.3 or upper!
2021-08-12	7.6		7.11	Update firmware from 7.06 to 7.11 (SDK 7.16.01.02) NB! Requires Z-Way v3.2.1 or upper!
2022-05-15	7.13		7.21	Update firmware from 7.13 to 7.21 (SDK 7.17.01) NB! Requires Z-Way v3.2.3 or upper!
2022-06-14	7.21		7.28	Update firmware from 7.21 to 7.27 (SDK 7.17.02) NB! Requires Z-Way v3.2.3 or upper!
