Razberry 7 firmware update to 7.28
etnica
Post by etnica »
trying to figure out howto get my razberry to latest firmware.
It comes with 7.15.0 from what I can see in expert ui.
Screenshot 2022-08-18 at 20.22.18.png (53.78 KiB) Viewed 6823 times
Want to get to
7.28 / 07.17.02.01 SDK 7.17.02. Fixes network stability bug in SiLabs SDK
The docs says, update firmware in expert ui and that is about it. Found deep down a link to a graph, but I have no idea howto follow that. Also can't find 7.17 in graph.
https://service.z-wave.me/expertui/uzb- ... graph.html
EDIT:
Could it be I should use this url?
https://service.z-wave.me/expertui/uzb/ ... .01.02.gbl
and then
https://service.z-wave.me/expertui/uzb/ ... .02.01.gbl
lanbrown
Re: Razberry 7 firmware update to 7.28
Post by lanbrown »
The easiest method as discussed in another thread, use token "all". You will then see 7.21 as an update. Update to it and after the upgrade is done, go back to the firmware update and use the token "all" again and then select 7.28 as the upgrade.
You do know that this firmware is not a general release? They still have some issues to fix. This is why these updates are not showing up in the firmware update.
etnica
Post by etnica »
No I do not know it's not general release. Doesn't say that on the firmware page?
Hmm on my firmware update page I only have the option to upload a file or insert an url. (fresh install of z-way)
Screenshot 2022-08-18 at 20.42.26.png (104.97 KiB) Viewed 6817 times
edit: perhaphs you ment all on graph page? If so would "active" mean stable release and "all" dev+stable releases?
Still don't understand how to follow the versioning in the graphs, those number really says nothing to me without any doc.
Arrows go 7.15 -> 7.13 -> 7.21, wouldn't it be 7.13->7.15.->7.21 ?
Screenshot 2022-08-18 at 20.57.55.png (80.82 KiB) Viewed 6810 times
Also getting confused on what "firweware/sdk" I really have on my device. 7.15.00 does not seem to exist.
lanbrown
Post by lanbrown »
Then looks like they finally official released it.
You are not looking at the correct page, go to Network -> Controller Info and then look near the bottom for firmware update. The page you're on is usually where you update the firmware for Z-Wave devices. There was a thread on all of this under the correct category. You might want to look at the Razberry sub-forum and look at that thread before proceeding any further.
etnica
Post by etnica »
Thanks :D
That page worked better.
But seems only 7.13 was shown. Can see 7.21 if i enter token "all" but don't want to upgrade if it's not stable.
