Interference from SATA SSD
sergrossi
Post by sergrossi »
Warning.
The SSD drive installed at the bottom of the Raspberry board can interfere and Z-Way does not see the RaZberry 7 Pro with external antenna.
I had to connect the drive with a 50 cm USB cable.
From my own experience.
Case for example:
Raspberry Pi 4, Raspberry Pi OS Lite (Debian version: 11 (bullseye),
Z-Way for Raspberry Pi, RaZberry 7 Pro, RaZberry 2
Re: Interference from SATA SSD
Do you mean that the presense of the SSD behind the Pi affected UART communication? Sure there were no short circuit or bad wiring?
sergrossi
Post by sergrossi »
Maybe it coincided.
I install Z-Way on SD card - everything works
I install Z-Way on an SSD drive - and Z-Way does not see RaZberry 7 Pro
I install Z-Way on an SSD drive via USB cable - everything works
And so twice, then I got tired of experiments, left it on the cable.
