UART-USB adapter for RaZberry 7Pro
sergrossi
Post by sergrossi »
I didn't wait for USB RaZberry 7Pro and bought a hat for Raspberry.
Tell me, please, is it possible to connect RaZberry 7 Pro to USB using any UART-USB adapter?
If so, please share the solution that works.
I want to install Z-Way on a virtual machine ESXI.
Thank you.
Raspberry Pi 4, Raspberry Pi OS Lite (Debian version: 11 (bullseye),
Z-Way for Raspberry Pi, RaZberry 7 Pro, RaZberry 2
seattleneil
Re: UART-USB adapter for RaZberry 7Pro
Post by seattleneil »
Definitely possible. I do this using an inexpensive USB to TTL Serial Converter (4 converters for $10.88 - https://ww.amazon.com/dp/B07XF2SLQ1) and 4 jumper wires ($6.98 - https://www.amazon.com/dp/B01EV70C78). Note that the converter has a mini-USB connector (not USB-C or micro-USB) and does not use a genuine FT232RL chip (functionality seems the same as a genuine FT232RL, but the serial number is not unique which likely will result in random serial port assignments when using multiple converters on a single host).
sergrossi
Post by sergrossi »
Thanks a lot for the detailed answer!
I understand correctly that you used
Raspberry Pi - PIN
PIN 02 - 5v DC Pover - this is the most important question - 3.3v or 5v
PIN 06 - Ground
PIN 08 - GPIO14(TXD0)
PIN 10 - GPIO15(RXD0)
seattleneil
The RaZberry uses 3.3V (pin 1 of Raspberry Pi), do not use pin 2 (5V). The remaining pins are correct. As shown in the picture, I use pin 9 for Ground, pin 6 is also Ground - either pin is correct. If you purchase the knock-off USB to TTL Serial Converter that I use, be sure to set the jumper on the serial converter to 3.3V.
As a precaution, before connecting the RaZberry board to the serial converter, I recommend testing with a voltmeter to verify the red wire/brown wire voltage is +3.3V.
If you install an Ubuntu-compatible distro on your VM, you should be all set. I use Linux Mint 20.3 (Ubuntu Focal) with Z-Way for Ubuntu x64.
sergrossi
Post by sergrossi »
Thank you! On your advice, I also chose Linux Mint.
Ordered USB to TTL Serial Converter.
sergrossi
Post by sergrossi »
I was unable to forward UART-USB in Linux Mint. It's easy on Home Assistant (debian), easy on Windows too.
Is there any secret?
seattleneil
What do you mean by "unable to forward UART-USB"? If "forwarding" is related to running linux Mint as a virtual machine on a VMware ESXi host, please understand that this is a Z-Wave.Me forum and not a VMware forum. I suggest you search the internet for configuring VMware USB Passthrough (e.g., https://www.nakivo.com/blog/how-to-use- ... l-machine/).
If you're running linux Mint on a physical laptop (or you've successfully configured VMware USB Passthrough), run the command "lsusb" on your Mint machine to see if there's a USB serial device. This is what appears when I run lsusb:
$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 8087:0a2a Intel Corp.
Bus 001 Device 003: ID 0bda:57f0 Realtek Semiconductor Corp. HD WebCam
Bus 001 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
The serial port shows up as: Bus 001 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Now run the command "dmesg | grep FTDI" on your Mint machine to determine if the kernel has attached the serial device to a tty port (the tty port name is how Z-Way communicates to the RaZberry). This is what appears when I run dmesg | grep FTDI:
$ dmesg | grep FTDI
[    1.499493] usb 1-2: Manufacturer: FTDI
[    9.219666] usbserial: USB Serial support registered for FTDI USB Serial Device
[    9.219722] ftdi_sio 1-2:1.0: FTDI USB Serial Device converter detected
[    9.225747] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
What you are want/need to see is the FTDI "ttyUSB0" serial device. The last step is to configure Z-Way to communicate using ttyUSB0. This is done using the smarthome web UI -> configuration menu -> Apps -> Z-Wave Network Access -> Settings. The settings shown below work (on my laptop running linux Mint). As best as I can recall, the only setting that needs to change is "Serial port to Z-Wave dongle" to /dev/ttyUSB0.
Apps_ZWave Network Access.JPG (150.39 KiB) Viewed 13625 times
Good luck.
sergrossi
Post by sergrossi »
Thank you very much!
Thanks to your help, I was able to find the error.
I forgot to change to - /dev/ttyUSB0
p_carneyrn
Post by p_carneyrn »
Does this pass a valid Z-way license to Z-way running on a VM setup?
Yes, VM should be transparent for the USB/UART communication
