C++ requires a type specifier for all declarations
Re: C++ requires a type specifier for all declarations
@amatilda
I used the links for 3.7 and it resolved the issues.
Where did you get this link?lanbrown wrote: ↑27 Aug 2022 07:48
It should actually be this URL:
https://z-uno.z-wave.me/files/z-uno2/pa ... index.json
It was a guess. When I kept seeing errors about the toolchain and for the G1 board, I thought that maybe the link in the documentation was wrong. So I added a 2 to z-uno to see if that would work and it did. Well, sort of. It no longer complained about a G1 toolchain for a G2 board but still had the issue with compiling. I believe PoltoS is going to update the links/documentation for the G2 which should alleviate the issue.amatilda wrote: ↑29 Aug 2022 19:22Where did you get this link?lanbrown wrote: ↑27 Aug 2022 07:48
When uploading the sketch I get this error and that file is not there:
There is a file that is similar in name of OneWire_temperature_sensor_DS18B20.ino
I cannot find the file anywhere. I'm using 3.7 (listed as 3.07). I tried the beta (3.8) but it produced even more errors.
So there is light at the end of the tunnel.
Couldn't determine program size
Needed file "C:\Users\user\AppData\Local\Temp\2\arduino_build_253281\OneWire_temperature_sensor_DS18B20_ino_signed.bin" doesn't exist. Build the sketch first!
An error occurred while uploading the sketchI cannot find the file anywhere. I'm using 3.7 (listed as 3.07). I tried the beta (3.8) but it produced even more errors.
lanbrown wrote: ↑29 Aug 2022 20:00When uploading the sketch I get this error and that file is not there:There is a file that is similar in name of OneWire_temperature_sensor_DS18B20.inoCode: Select all
Couldn't determine program size Needed file "C:\Users\user\AppData\Local\Temp\2\arduino_build_253281\OneWire_temperature_sensor_DS18B20_ino_signed.bin" doesn't exist. Build the sketch first! An error occurred while uploading the sketch
"When uploading the sketch I get this error and that file is not there" - what sketch and what version of z-uno?
" I tried the beta (3.8) but it produced even more errors" - last 3.9
It is a G2. 3.7 and the IDE is 1.8.19
It is this sketch:
https://z-uno.z-wave.me/examples/multip ... e-sensors/
It is this sketch:
// Multiple temperature sensors DS18B20
#include "ZUNO_DS18B20.h"
#define DS18B20_BUS_PIN 11 // Pin to which DS18B20 bus is connected
#define N_SENSOR 3 // Number of DS18B20 sensors
// You need to adopt ZUNO_SETUP_CHANNELS and add more getters if tou need more sensors
OneWire ow(DS18B20_BUS_PIN);
DS18B20Sensor ds18b20(&ow);
#define ADDR_SIZE 8 // Size of address of devices on 1-wire bus
byte addresses[ADDR_SIZE * N_SENSOR]; // Here we store all the scanned addresses
#define ADDR(i) (&addresses[i * ADDR_SIZE]) // Macro to simplify our life
byte number_of_sensors; // Number of sensors found
word temperature[N_SENSOR]; // Here we store temperatures
// Define Z-Wave channels. Add more if you need more sensors
ZUNO_SETUP_CHANNELS(
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp1),
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp2),
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp3)
void setup() {
number_of_sensors = ds18b20.findAllSensors(addresses);
void loop() {
for (byte i = 0; i < number_of_sensors && i < N_SENSOR; i++) {
// Read temperature
temperature[i] = ds18b20.getTemperature(ADDR(i)) * 100;
// Sending report
zunoSendReport(i + 1); // Channels starts from 1
delay(30000);
// Getters. Add more if you need more sensors
word getterTemp1() {
return temperature[0];
word getterTemp2() {
return temperature[1];
word getterTemp3() {
return temperature[2];
}Re: C++ requires a type specifier for all declarations
I have this code compiled and loaded successfully.lanbrown wrote: ↑29 Aug 2022 20:18It is a G2. 3.7 and the IDE is 1.8.19
It is this sketch:
// Multiple temperature sensors DS18B20 #include "ZUNO_DS18B20.h" #define DS18B20_BUS_PIN 11 // Pin to which DS18B20 bus is connected #define N_SENSOR 3 // Number of DS18B20 sensors // You need to adopt ZUNO_SETUP_CHANNELS and add more getters if tou need more sensors OneWire ow(DS18B20_BUS_PIN); DS18B20Sensor ds18b20(&ow); #define ADDR_SIZE 8 // Size of address of devices on 1-wire bus byte addresses[ADDR_SIZE * N_SENSOR]; // Here we store all the scanned addresses #define ADDR(i) (&addresses[i * ADDR_SIZE]) // Macro to simplify our life byte number_of_sensors; // Number of sensors found word temperature[N_SENSOR]; // Here we store temperatures // Define Z-Wave channels. Add more if you need more sensors ZUNO_SETUP_CHANNELS( ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp1), ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp2), ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp3) ); void setup() { number_of_sensors = ds18b20.findAllSensors(addresses); } void loop() { for (byte i = 0; i < number_of_sensors && i < N_SENSOR; i++) { // Read temperature temperature[i] = ds18b20.getTemperature(ADDR(i)) * 100; // Sending report zunoSendReport(i + 1); // Channels starts from 1 } delay(30000); } // Getters. Add more if you need more sensors word getterTemp1() { return temperature[0]; } word getterTemp2() { return temperature[1]; } word getterTemp3() { return temperature[2]; }
Try reinstalling z-uno by uninstalling it manually first.
I completely uninstalled the IDE, deleted any directories that were left, installed the IDE and the 3.7 board manager. Still the same error:
Arduino: 1.8.19 (Windows Server 2016), Board: "Z-Wave>ME Z-Uno2, USA, Enabled, Normal +0dBm"
Needed file "C:\Users\user\AppData\Local\Temp\2\arduino_build_929741\sketch_aug26a_ino_signed.bin" doesn't exist. Build the sketch first!
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
And if you try to only compile the sketch?lanbrown wrote: ↑29 Aug 2022 21:39I completely uninstalled the IDE, deleted any directories that were left, installed the IDE and the 3.7 board manager. Still the same error:Code: Select all
Arduino: 1.8.19 (Windows Server 2016), Board: "Z-Wave>ME Z-Uno2, USA, Enabled, Normal +0dBm" Couldn't determine program size Needed file "C:\Users\user\AppData\Local\Temp\2\arduino_build_929741\sketch_aug26a_ino_signed.bin" doesn't exist. Build the sketch first! An error occurred while uploading the sketch This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
Arduino from windows store?
If I click verify, the only error is that it cannot determine the size.
I've attached screenshots for the verify and the upload.
Needed file "C:\Users\ADMINI~1\AppData\Local\Temp\2\arduino_build_929741\sketch_aug26a_ino_signed.bin" doesn't exist. Build the sketch first!
An error occurred while uploading the sketch- Attachments
- Screen Shot 2022-08-30 at 12.43.16 PM.png (215.81 KiB) Viewed 12684 times
- Screen Shot 2022-08-30 at 12.18.35 PM.png (908.31 KiB) Viewed 12684 times
- Screen Shot 2022-08-30 at 12.18.15 PM.png (75.16 KiB) Viewed 12684 times
