which port needed to bind Z-Wave ZMEERAZ2 module?
Scoo
Post by Scoo »
hi,
i just installed the zwave-me server on my raspy B2 an have a Z-Wave ZMEERAZ2 Z-Wave.Me RaZberry 2 Module.
The server always tells me to proof, if the controller is connected an the correct port in the app is set.
The message gives me following possible ports:
UZB: '/dev/ttyACM0', RaZberry Shield: '/dev/ttyAMA0', UZB-Windows: '\\.\COM3', Z-Stick: '/dev/ttyUSB0', embedded boxes: '/dev/ttyS0' or '/dev/ttyS1'
in the app "Z-Wave Network Access" -
i tried the ttyACM0 and the ttyAMA0 and the versions with "/dev/ttyAMA0" but nothing works for me.
i found a hind, to check the port via terminal, i tryed "grep" command and got following:
(the other ports led to a blank output line
pi@homebridge:/var/lib/homebridge $ dmesg | grep ttyAMA0
[ 3.722589] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Can anyone help me an tell, what i'm doing wrong?
lanbrown
Re: which port needed to bind Z-Wave ZMEERAZ2 module?
Post by lanbrown »
Did you make the changes to the config.txt file located in /boot
It depends on the which Pi you're using but it should be something like these:
dtoverlay=miniuart-bt
or
dtoverlay=pi3-miniuart-bt
