Razberry bricked? Can't write NVM data at=3000
woekids
Post by woekids »
My Razberry, installed on a PI4b, was updating but became to hang.
At restart the red/green light blinked once and after that ....... DEAD!!
The hat is not recognized anymore.
Return text after flashing:
Opening port ................... OK
Writing NVM data .................. FAILED
Error 0 Unknown exception: Can't write NVM data! at=3000
Is he bricked and do I have to throw it away or is there a way to rescue my Razberry?
Re: Razberry bricked? Can't write NVM data at=3000
Is it a RaZberry 7 or RaZberry 2?
woekids
Post by woekids »
Razberry 2
Can you use Z-Way with it?
woekids
Post by woekids »
No it is not recognized anymore. When the raspberry starts up the red and the green led lit up once and that was it.
If no other changes were made, it looks like a h/w fault. Might it be that you change something on your Pi? Maybe UART setting were changed?
woekids
Post by woekids »
I also tried on other raspberry’s pi with the same result. Therefor I am afraid the hat is bricked.
Heffner2
Post by Heffner2 »
I'm sorry to hear about the issues you're experiencing with your Razberry installed on a Raspberry Pi 4B. It seems that the device encountered an error during the flashing process and is currently not being recognized.
