No, it is in the C code, not in JS. But changes are very small and we need a way to reproduce it or understand how it happened. So please provide us with more info.
johanneslarsson
Post by johanneslarsson »
Ok, is the c code also open source and available on github?
I'll try to compare the logs from 4.0.3 vs 4.1.0 later.
No need to compare logs. Please reproduce the queue stuck and send us the extended queue inspector page in the debug v4.1.0-23 together with the log
johanneslarsson
Reverting to 4.0.3 works like charm. But here we go, installed the version you mentioned. Anything else I need to get the debug enabled?
PKG=z-way-4.1.0-23-g89a32d68-lws16_armhf.deb && wget -O /tmp/$PKG https://storage.z-wave.me/z-way-server/$PKG && sudo dpkg -i /tmp/$PKG
You can check the Inspect Queue in the Expert UI - it should contain many columns (you might need to clear the browser cache). This is what we will need (together with the log) once it hangs.
johanneslarsson
Soon 24h without hanging. We just have to wait or is there any differences in this 4.1.0-23 version?
The only difference is that queue inspector shows more fields. No changes in the queue handling. So we need to wait.
Thanks for your help!
thomas@unverzagt.org
Post by thomas@unverzagt.org »
Hi.
Same Problem here.
It seems to me that one single device w/o responding can block the JQ.
E.g. a battery device which ran low or a device which was sent a GET but which has long way to go to its next wakeup.
BR
Thomas
@thomas@unverzagt.org please provide your log file and the queue inspector view (screenshot or better save the html page) (click on Jobs on the top of expert UI)
If someone with the issue can provide remote access during such hang, would be perfect
