Razberry Pro Firmware / SDK
thaui
Re: Razberry Pro Firmware / SDK
Post by thaui »
@ScottR already used 'all' no update at all.
@PoltoS what is the last available update?
ScottR
Post by ScottR »
@Thaui.
This worked for me with the latest Z-Way v4.1.1 release and was able to update to 7.38.
thaui
Post by thaui »
@ScottR thanks for the reply. I have used z-way version 3.xx. maybe I need to update to 4.1.1. will try and give my feedback.
thaui
Post by thaui »
@ScottR I updated z-way to 4.1.1 and the firmware update for the Razberry pro to 7.38 worked well. Thanks for you input
lp2067
Post by lp2067 »
CorC wrote: ↑
02 Jul 2023 10:53
I have the same issue ever since the upgrade to the new firmware.
Need to do a full power off to restore functioning, reboot won’t cut it.
If you are interested in logs please let me know which ones you are interested in.
Same issues. After few hours of work there are
"Error returned from _zway_cc_call_handler(zway, device->default_instance, NODE_BROADCAST, 0, data[4 + L], &data[5 + L]): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)"
then
"Got frame from device XX to controller, but device is not registered - do re-inclusion" for non-existing devices
then devices are marked as dead...
Reboot Raspberry does nothing. Only power cycle works.
Your firmware version are worse and worse...
lp2067
Post by lp2067 »
Reverted to Razberry 2 - works without problems.
Who got problems - do the same.
EOT.
harre
Post by harre »
lp2067 wrote: ↑
20 Sep 2023 09:12
EOT.
I'll try my old razzberry and see how it behaves. It's a bit sad that stuff that have worked for years just stop working and then when reporting issues with logs nothing more happens.
Gaby
Post by Gaby »
I am running 7.36 [Bootloader: 65535] and want to upgrade to 7.38. when I type 'all' in access token field I do not get the choice of 7.38, any hint?
What is your hardware? It is strange that the bootloader is 65535... Please let me know the uuid of the hardware (you can see it in Z-Way Controller Info page)
Gaby
Post by Gaby »
Razberry 7 Pro on Raspberry 4B 8GB, FW: v7.36 SDK: v7.19.2
