Home Automation - Roller Shutter
SolarFlor
Re: Home Automation - Roller Shutter
Post by SolarFlor »
Dolam the italian user, have downloaded the last HA but still the Roller Shutter doesn't work.
Hi Shepotronic,
are your shutter roller working now?
SolarFlor
Post by SolarFlor »
Anybody can help?
We have not tested much blinds in HA. Hope to do it in coming days
SolarFlor
Post by SolarFlor »
My friend have loaded an old image with the version 1.5.0 and the old HA. He can see now the Roller Shutter in HA but as a Dimmer.
Using 1.7.0 and the latest HA, nothing
should work in latest github commit - tested on my FGRM-222
SolarFlor
Post by SolarFlor »
I have update Z-Way to 1.7.1-rc2 and HA.
On UI Expert I can see the Roller Shutter (see image 1) but in HA it appears as a Dimmer (see Image 2)
Image 2
Image 2
Image 1
Image 1
This change was after latest rc2. Please try from git.
SolarFlor
Post by SolarFlor »
You mean to update HA UI?
SolarFlor
Post by SolarFlor »
I have another problem with the Roller Shutters:
I have installed two different types, the Fibaro FGR 211 that is working well and the FGRM 222 that is seen as a switch and not as a roller shutter
BetterClimate
Post by BetterClimate »
I have the same problem with the FIBRARO ROLLER SHUTTER FGRM-222 (Roller Shutter 2).
It is possible to calibrate it, and all the setting work but I can only open and close it.
While the positioning should have improved compared to version FGR-221 it is not possible.
It looks like the Multi-level-switch command class is missing?
