error with new board on install
deejc
Post by deejc »
hello,
i have installed the new board i received today in my rpi, but i cannot get it to connect.
i get
Notification: critical (z-wave): Can not start Z-Wave binding: Error: Binding with name 'zway' already exists
/bin/ls: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.26, BuildID[sha1]=0x7f981e03f231371c5feaaeab28d9e23639e57cd3, stripped
Linux raspberrypi 3.12.35+ #730 PREEMPT Fri Dec 19 18:31:24 GMT 2014 armv6l GNU/Linux
Z-Way version v2.0.0 from 2014-12-08 19:54:26 +0300 (build a064f5408850947aed035bc9170e1fa04f0fd2ec)
Looking for modules in ./modules
Module modzwave.so loaded
Module moddhs.so loaded
Module modenocean.so loaded
Module modhomekit.so loaded
cURL 7.26.0 likely has DNS timeout bug. Please update cURL. Disabling sync DNS timeouts for now.
Module modhttp.so loaded
Module modws.so loaded
full log at http://paste.debian.net/137475
dmesg http://paste.debian.net/137477
i actually cannot get it to do anything right now, there is a date of 05.12.14 on the board and the rpi is a b+
On first power on the leds flash red/green but then go off.
Serial port to Z-Wave dongle in the UI is /dev/ttyAMA0, i have run rpi-update and did full updates on all software.
Re: error with new board on install
Your RaZ starts normally: self test passed, LED goes off.
But your B+ does not see it as AMA0. Two possible reasons:
1) wrong pins - it should be installed as on the image in the manual - on the corner of the board (pins are named incorrectly in some manuals).
2) configuration of AMA0 went wrong during installation. Need to see /etc/inittab and /boot/cmdline.txt
deejc
Post by deejc »
thanks, i put it on the first set of pins, still not working, i installed raspian base os, installed z-way on the base OS, still not working.
i am returning it.
Not sure it is a problem of RaZberry. May be B+ ports are configured in a different way. May be try another board from your shop or another Raspeberry (depending which is easier to get). In theory it is possible to burn RaZberry board by installing on wrong pins, but we have never seen this yet.
deejc
Post by deejc »
i bought a new board, and it works perfectly.
