I am using Windows 10.
I have installed Arduino IDE 1.6.5 as described.
When I install Z-Uno 2.0.5 or 2.0.6 then the error "CRC doesn't match..." occurs.
Is there a sollution?
[closed] 2.0.5 and 2.0.6. CRC doesn't match
ronaldsnoeck
- crc.jpg (61.11 KiB) Viewed 12734 times
Re: 2.0.5 and 2.0.6. CRC doesn't match
What is your current (installed) version - and what Update URL you are using?
Michael
Michael
A.Harrenberg
I had the same issue... I just de-installed Arduino and made a new, clean installation (with the update-URL http://z-uno.z-wave.me/files/z-uno/pack ... index.json URL as described here). Then I was able to install 2.0.6 without that error. It seems that as soon as you try to switch between 2.0.5 and 2.0.6 there is miscalculation of the CRC...
Regards,
Andreas.
Regards,
Andreas.
ronaldsnoeck
I switched off the virus scanner.
I un installed all and even deleted all data in "C:\Users\Ronald\AppData\".
I followed http://z-uno.z-wave.me/install
Still no success.
I have another error see att
Regards,
Ronald
Still no success.
Regards,
Ronald
- error.jpg (64.88 KiB) Viewed 12717 times
A.Harrenberg
that is strange, in the current error message the path contains "//" which is probably the cause of the error, but I have no idea wheres this would come from...
I can try it on my laptop to verify that it still works on my end, but I can't do it before tommorrow evening.
Regards,
Andreas.
Regards,
Andreas.
ronaldsnoeck
Hi Andreas,
at home I repeated the whole procedure again. Now with the target (zuno) connected.
Now it works.
thanks,
Ronald
Now it works.
thanks,
Ronald
