Problem with Raspberry Pi 3 / Z-Wave board
Jeff66
Post by Jeff66 »
Hi
I'm new to z-wave. I have an old background in Unix and I'm interested in automation. So I decided to try to setup a Pi 3 with Z-Wave.
I tried with noobs, learned it, switched to jessie. Tried almost all the images available. With no success.
I'm able to setup the PI, connect in Ethernet or WiFi to my network. Able to setup the Z-Wave interface (or Jeedom)
I did all what was recommended to avoid the UART problem. But my Z-Wave network won't work.
I checked the board, the test is OK.
I measured the GPIO pins, voltage is OK.
I think I have an issue with the network. I edited my /etc/hosts. Changed the speed of the TTY, under clocked the PI, nothing works.
Which device tree is the right one to add at the end of /boot/config.txt ?
Is it pi3-disable-bt or pi3-miniuart-bt ?
What could prevent Z-Wave to communicate ?
I have a Raspberry Pi 3 Model B V1.2 2015 with a Z-Wave which looks like a Serie 500. But it looks like a mix between the image of the 300 and the 500 when I look at the images on http://razberry.z-wave.me
Thanks for your help ! :geek:
phzi
Re: Problem with Raspberry Pi 3 / Z-Wave board
Post by phzi »
Have you tried the RPi 3 image that z-way team put out?
http://razberry.z-wave.me/z-way-server/ ... i3.img.zip
Jeff66
Post by Jeff66 »
Just downloaded and installed.
Upgraded to 2.2.5 through IP:8084
Done a raspi-confi and set the locale, country, time zone, etc
Connected in ssh under pi@My_local_ip to setup the WiFi (with sudo nano /etc/wpa_supplicant/wpa_supplicant.conf)
Wifi connection works fine.
Connected in admin expert mode.
Added Meteo App, works fine
But Z-Wave still tells me : Cannot start Z-Wave binding: Error: Bad data - communication failed
In Expert mode, under Network / Controller Info, I get Error handling data from server
Tried to send Controllen NIF, got Error handling data
/ZWaveAPI/Run/controller.SendNodeInformation()
I'm stuck. Any idea ?
Z-Wave Support
Post by Z-Wave Support »
can you send a picture from your Razberry and a picture from Error?
Please check the Port from the Razberry.
Z-Wave Support Team
Jeff66
Post by Jeff66 »
Here are the pictures
Razberry
Razberry
RPI 3
RPI 3
Board mounted
Board mounted
Jeff66
Post by Jeff66 »
Thank you for helping me !
Which picture of error do you want ? I can post /var/log/z-way-server.log or a screen copy of the various error that I get on my html interface. Just let me know what you want.
Jeff66
Post by Jeff66 »
And here a picture of the error
Capture d’écran 2016-11-28 à 22.13.11.png (92.67 KiB) Viewed 23705 times
Cmax74
Post by Cmax74 »
Hi !
Try a clean install and login as User "pi".
Then Update Raspberry 3 Firmware for stability work with commands:
sudo apt-get install rpi-update
sudo rpi-update
After this, install the zwave Software as pi User:
This was the way that helps me :D
Raspi 3, Zwave.me 4.1.0.
Jeff66
Post by Jeff66 »
Done as per your instructions
Still getting :
22:20 | Cannot start Z-Wave binding: Error: Bad data - communication failed
Z-Wave Support
has you restart you system after installing Z-Way?
Please check the Port and your bootloader in the expert UI.
regards
Z-Wave Support
