Changing the country frequency
vijayg78
Post by vijayg78 »
I bought a Razberry Z wave daughter board from online (India) and they issues the EU frequency (2 years back approx). Its a 5th gen board. Now I see there is a specific frequency allocated for IN.
I also noticed that now the Country can be changed via the admin UI . I want to confirm that the country can be changed via UI. Is that possible or allowed? If i do that will I be able to use the IN specific devices with this board?
When i try to change the country, nothing happens, it just stays in the same page and i see the current frequency as "Unknown". Please let me know what step i am missing.
Really appreciate the support,
Best Regards,
Vijay
Hardware
Vendor: RaZberry by Z-Wave.Me
Vendors Product ID: 1024 / 1
Z-Wave Chip: ZW0500
Software Information
Version number: v2.2.5
Compile-ID: d58b7617c4f553beca4c6f41705b48fa5a4cf56c
Compile-Date: 2016-11-15 11:42:15 +0300
Firmware
SDK Version: 6.51.03
Serial API Version: 05.00
Z-Wave Support
Re: Changing the country frequency
Post by Z-Wave Support »
please Update your Bootloader about Expert UI (First Bootloader, then Firmeware).
Best regards
Z-Wave Support
vijayg78
Post by vijayg78 »
Sorry to ask this, how to update Bootloader? Will just "wget -q -O - razberry.z-wave.me/install | sudo bash" update boot loader also? If that is the case i already did that. But Firmwire update is not going through.
Regards, Vijay
vijayg78
Post by vijayg78 »
In the Expert UI i do not get an option to update the bootloader. The firmwire update is not going through from this page.
Z-Wave Support
you can update your Bootloader in http://IP:8083/expert/#/network/controller.
good luck
regards
Menu in Expert UI
Menu in Expert UI
Firmware raz 2.PNG (66.04 KiB) Viewed 11151 times
Update Button
Update Button
Firmware raz 1.PNG (24.66 KiB) Viewed 11151 times
Firmeware button
Firmeware button
Firmware raz 0.PNG (30.01 KiB) Viewed 11151 times
vijayg78
Post by vijayg78 »
It did not help, for this URL i am getting a message "Could not retrieve data from remote server.". What might be the issue?
Regards, Vijay
vijayg78
Post by vijayg78 »
Finally solved it via below step.
Downgraded to 2.2.2, did a fresh install to a new SD card. Used the browser in incognito mode (Very Important), i was able to see the options. Did upgrade of bootloader and firmwire. Then did reboot everything was ok.
Did a shutdown and swap of SD card, back to normal.
Thanks for the help,
Regards, Vijay
