updating metering values
thaui
Post by thaui »
the update of the messured values from the meters is not working. Switching of a lamp is not reducing the usage. Also KWh must be updated manually. I am running the meter update app but without any success.
jensmoes
Contact:
Re: updating metering values
Post by jensmoes »
What meter are you using?
thaui
Post by thaui »
I am using 4 taphome socket plugs and one fibaro socket plug. All 5 showing the same behavior. You need to push the update button otherwise the kwh are not updated by themself.
jensmoes
Contact:
Post by jensmoes »
It sounds like the devices are not sending unsolicited reports.
The fibaro one:http://www.fibaro.com/files/instrukcje/ ... %20ENG.pdf can be configured with parameters 40-49 for reporting in various ways.
Have you tried playing with those to see if it makes any difference in behavior?
thaui
Post by thaui »
I guess it has nothing to do with the device configuration. Since I am using the new HA Gui the problems appeared. Until HA Gui Ver. 21 or so they responded fluently.
