updating metering values
the update of the messured values from the meters is not working. Switching of a lamp is not reducing the usage. Also KWh must be updated manually. I am running the meter update app but without any success.
Re: updating metering values
What meter are you using?
I am using 4 taphome socket plugs and one fibaro socket plug. All 5 showing the same behavior. You need to push the update button otherwise the kwh are not updated by themself.
It sounds like the devices are not sending unsolicited reports.
The fibaro one:http://www.fibaro.com/files/instrukcje/ ... %20ENG.pdf can be configured with parameters 40-49 for reporting in various ways.
Have you tried playing with those to see if it makes any difference in behavior?
I guess it has nothing to do with the device configuration. Since I am using the new HA Gui the problems appeared. Until HA Gui Ver. 21 or so they responded fluently.
