A Beautiful Routing Table?
bawesto
Re: A Beautiful Routing Table?
Post by bawesto »
It's the part up from click on "Update" in Routing Table for Device 29. And it's an existing Device, not new.
How should I start "Update" if not existing before?
As you see it starts with "Request node neighbours update"
Nothing else in the meantime.
Then, 100 ms later you can find a "New node 29 was assigned" and it seems to start Interview.
This is normal on "Update Route" :?: :?: :?:
Up from Line 189 you find:
[2017-01-06 21:06:32.066] [core] Deleting device switchBinary ZWayVDev_zway_29-0-37
[2017-01-06 21:06:32.155] [core] Deleting device sensorMultilevel ZWayVDev_zway_29-0-50-0
[2017-01-06 21:06:32.162] [core] Deleting device sensorMultilevel ZWayVDev_zway_29-0-50-2
[2017-01-06 21:06:32.166] [core] Deleting device sensorMultilevel ZWayVDev_zway_29-0-50-4
[2017-01-06 21:06:32.169] [core] Deleting device sensorMultilevel ZWayVDev_zway_29-0-50-5
This seems to be the point where my existing devices are deleted.
Then again "New node 29 was assigned" and again Interview start.
But with no succes.
As i told, the Result is loosing all Interview-Data for the Device, all Items removed in UI.
I can bring it back with "Force Interview", or by Re-Inclusion. But this works only for Devices near to the HUB.
If there is no better Solution, i will keep my fingers from this Update-Buttons an hope for next version bringing back a good working Network Reorganisation.
Or try good old Reorganisation-Method powering off HUB for more then 15 Minutes.
But if i read post from Threadstarter, i fear this will make things even worse :shock:
Looks like RaZberry do not understand the device is here. Can see with remote support, since otherwise I've no idea...
bawesto
Post by bawesto »
How does the Logfile look on a working Route Update Process?
Is start of Interview normal?
And some more basic Questions to this Topic:
Does the "Request node neighbours update" trigger the Deice to Re-Scan its Neighborhood and Update its own Routingtable? Or is it just a Query for the Devices Table "as it is" and has been build on include?
The very Basic Question for me is: How to get a beautiful Routing Table.
I realy searched for this, but found conflicting Answers. Where to include a new Device? Is it true routing is build on include an then static? Then it makes Sence to Include at its Endposition. But what if it's to far away from the Hub and Inclusion does not work?
Bring the Hub to the Device? Then Table would be right except the Route to the Hub itself and the Table in the Hub.
Or include near the Hub, bring it to its Endposition and request Update Route. This is what I tried and leaded me to this Topic.
No, it should not trigger interview.
bawesto
Post by bawesto »
I have tried to force Update of Routing by power off Razpi for 15 Minutes. At first there was no difference in Routing-Table, but now Update is working as it should! I have updated every Device an now it is a "beautiful Routing Table".
