How should I start "Update" if not existing before?
As you see it starts with "Request node neighbours update"
Nothing else in the meantime.
Then, 100 ms later you can find a "New node 29 was assigned" and it seems to start Interview.
This is normal on "Update Route"
Up from Line 189 you find:
[2017-01-06 21:06:32.066] [core] Deleting device switchBinary ZWayVDev_zway_29-0-37
[2017-01-06 21:06:32.155] [core] Deleting device sensorMultilevel ZWayVDev_zway_29-0-50-0
[2017-01-06 21:06:32.162] [core] Deleting device sensorMultilevel ZWayVDev_zway_29-0-50-2
[2017-01-06 21:06:32.166] [core] Deleting device sensorMultilevel ZWayVDev_zway_29-0-50-4
[2017-01-06 21:06:32.169] [core] Deleting device sensorMultilevel ZWayVDev_zway_29-0-50-5
This seems to be the point where my existing devices are deleted.
Then again "New node 29 was assigned" and again Interview start.
But with no succes.
As i told, the Result is loosing all Interview-Data for the Device, all Items removed in UI.
I can bring it back with "Force Interview", or by Re-Inclusion. But this works only for Devices near to the HUB.
If there is no better Solution, i will keep my fingers from this Update-Buttons an hope for next version bringing back a good working Network Reorganisation.
Or try good old Reorganisation-Method powering off HUB for more then 15 Minutes.
But if i read post from Threadstarter, i fear this will make things even worse
