Can you give us your"some response in the expert menu"? This may help
And, is your siren responding if you switch it on manually in the menu?
Send Notification_report to play chime
Re: Send Notification_report to play chime
Hello enbemokel, thx for the reply and sorry for the delay. This Info i get from the expert Job Queue
1 D + + + 13.80 66 Alarm Delivered 42 a 71 5 0 0 0 0 6 16 0 0 25
I can switch the sirene on and off. But with the toggle button which i make with the Code device " zway.SendData(66,[113,5,0,0,0,0,6,22,0,0]) " i dont get any output.
Hi eyeq202,
just one note. If your siren communicates thru Security CC
use zway.SendDataSecure instead of zway.SendData
Bjoern
Bjoern
Hmm, your expert Job Queue is looking good for me, maybe Bjoerns answer is helpful.
thx for the reply guys.
@Bjoern : i try your suggestion but without any luck.
Is there any other chance to get this thing working proper ?
Sorry, no other idea. The command is delivered from your expert menu message, so the siren is not responding.
Maybe you should factory reset it and reinclude again for another test.
Oh, one more idea. Did you check in configuration tab that the 4 is set to 0?
Nº 7 - Customer Function
(0) ---
(1) ---
(2) ---
(3) ---
(4) Notification Type, 0: Using Notification Report. 1: Using Sensor Binary Report.
(5) ---
(6) ---
(7) ---
Updated: 2018-01-12 | Set value: 0 | Default value is: 0
(0) ---
(1) ---
(2) ---
(3) ---
(5) ---
(6) ---
(7) ---
Hi enbemokel, which configuration tab you mean ? Can you explain ?
thx
thx
Its WORKING !!!!! Thx guys. The info from enbemokel was great. Thx sooo much.
Thanks for information that it works
