Heating control nor climate control app are working
flarno11
Post by flarno11 »
Both the Heating control and the climate control app don't seem to work. I've defined a simple schedule, e.g. 7-22 to 21°, the rest to 17°. If I manually switch from time-driven to e.g. comfort mode and back, the right temperature according to the schedule is applied, but not automatically.
I don't see any log entry at 7am or 22pm in /var/log/z-way-server.log.
I am using a fresh installation of Raspbian buster from 2019-09-26, Z-Way Server 3.0.0, and just one Danfoss Living Connect.
michap
Contact:
Re: Heating control nor climate control app are working
Post by michap »
did you switch the "climate control" element to "time driven" ?
It will be added as element with your device.
Michael
flarno11
Post by flarno11 »
yes, as I wrote " If I manually switch from time-driven to e.g. comfort mode and back, the right temperature according to the schedule is applied"
vachah
Post by vachah »
Hi, did you solve this problem?
It seems I have the same one and nothing work for me.
worldnew29
Post by worldnew29 »
:shock: help! same issue. how to solve this problem? give some tips please. :) thanks in advance.
vapepenzone
Contact:
Post by vapepenzone »
the same problem! how you fix it?
Krooms
Post by Krooms »
I have the same problem.
Switching between „time driven“ and „comfort“ manually triggers the correct temperature, but staying in „time driven“ temperature doesn’t change according to my schedule.
Tried it with zway 3.0.4 and 3.0.5.
Gonna try it with a clean install of 3.0.5 tomorrow and see if it‘s working.
Iceman
Post by Iceman »
Same problem with Climate Control. Morning schedule works, but it doesn't come back to Saving Temperature at "End time" unless I enter in configuration and Save again or changing the operation mode and come back to "time driven". Schedule another period beginning at 21:01 neither works.
Screenshot from 2020-11-10 22-04-36.png (55.85 KiB) Viewed 11184 times
Thank you. Passed to our R&D so they look on it. Looks like it's getting cold in Europe
fez
Post by fez »
It would be nice to get an update with the fixed heating control, before the winter is over :)
