Both the Heating control and the climate control app don't seem to work. I've defined a simple schedule, e.g. 7-22 to 21°, the rest to 17°. If I manually switch from time-driven to e.g. comfort mode and back, the right temperature according to the schedule is applied, but not automatically.
I don't see any log entry at 7am or 22pm in /var/log/z-way-server.log.
I am using a fresh installation of Raspbian buster from 2019-09-26, Z-Way Server 3.0.0, and just one Danfoss Living Connect.
Heating control nor climate control app are working
Re: Heating control nor climate control app are working
did you switch the "climate control" element to "time driven" ?
It will be added as element with your device. Michael
yes, as I wrote " If I manually switch from time-driven to e.g. comfort mode and back, the right temperature according to the schedule is applied"
Hi, did you solve this problem?
It seems I have the same one and nothing work for me.
worldnew29
vapepenzone
- Contact:
the same problem! how you fix it?
I have the same problem.
Switching between „time driven“ and „comfort“ manually triggers the correct temperature, but staying in „time driven“ temperature doesn’t change according to my schedule.
Tried it with zway 3.0.4 and 3.0.5.
Gonna try it with a clean install of 3.0.5 tomorrow and see if it‘s working.
Same problem with Climate Control. Morning schedule works, but it doesn't come back to Saving Temperature at "End time" unless I enter in configuration and Save again or changing the operation mode and come back to "time driven". Schedule another period beginning at 21:01 neither works.
- Screenshot from 2020-11-10 22-04-36.png (55.85 KiB) Viewed 11183 times
Thank you. Passed to our R&D so they look on it. Looks like it's getting cold in Europe
It would be nice to get an update with the fixed heating control, before the winter is over
