@PoltoS,
I think my RaZ board is dead.. when the raspberry boot the RaZ board LED is red and I can't use it!
Is there a way that I can use my spare board (for sure I'm not having a backup) without having to reinclude all the devices?
RaZ board dead
Re: RaZ board dead
@PoltoS,
I finally managed to saved a lot of works by still having my old UZB paired to this network with an old backup!
Anyway, I managed to re-pair all the latest devices that I installed...
BUT, I'm having a couple of "dead" devices that I try to "delete" and they always come back and I'm having an error when deleting them.
Also, is the a way to do local backup of the config every day ?
Re: RaZ board dead
Delete failed nodes from Expert UI
You can do local backup using curl - the request for backup is simple via API call.
Re: RaZ board dead
@PoltoS,
Deleting from expert UI did nothing!
The device disappear from the list but come back again!
Re: RaZ board dead
Here's something in the log while deleting
- 2021-02-09 14_03_57-Z-Wave Expert UI — Firefox Developer Edition.png (2.03 KiB) Viewed 10033 times
Re: RaZ board dead
This means the chip was able to contact that device and marked it as alive back
Re: RaZ board dead
@PoltoS,
I did the entire house, room by room to took the z-wave inventory, also made an excel document
And I have no idea where these device can be... I even check my invetory before the crash and those device ID was not used...
Is it possible that a device answer to 2 different ID ?
Re: RaZ board dead
No, it is not possible. Though,... everything is possible in IT
Try to press Ping button on Status page and then remove again
